11-24-2010
It shouldn't be a problem with daytime temps in the 50˚s.
I'm not a big fan of ceramic heaters on boats, since they can tip and cause a fire pretty easily. If you are worried about the boat freezing, I'd highly recommend you pick up a couple of goldenrod heaters.
BTW, your insurance company would probably have an issue with you leaving ceramic heaters on while the boat is unattended.
