Old 05-15-2003
jhasailing is on a distinguished road
refinishing a tiller
i just bought a 1985 catalina 22. the wood tiller (not sure what kind of wood) needs refinishing but it is not in too bad of shape. i have stripped the old varnish off and am ready to do some sanding. does anyone have any tips about proceeding from here? should i just apply several coats of spar urythene? what about wood conditioner, stain, or other options?
thanks in advance
Old 05-15-2003
Sailormon6 will become famous soon enough
Don''t machine-sand the tiller any more aggressively than you have to, because you can weaken the tiller after 2-3 aggressive resanding jobs. You can stain it if you like. Polyurethane works well to cover it. Be sure that you coat the end grain well, and, if there are any holes drilled in it for screws or bolts, coat the insides of the holes with polyurethane, to discourage dry rot. If the tiller is laminated wood, rather than solid wood, never let a substantial amount of the polyurethane wear away, because it will delaminate. When the boat is not in use, the finish on the tiller will last much longer if it is covered with a Sunbrella tiller cover.
Tiller auto pilot wildlone Gear & Maintenance 10 03-08-2011 12:44 AM
Bottom refinishing on trailer? aflanigan Gear & Maintenance 2 10-10-2003 03:10 PM
tiller pilot for 38 Ingrid obiec Gear & Maintenance 0 05-10-2003 06:30 AM
Tiller auto pilots newuser Gear & Maintenance 8 01-21-2003 08:21 PM
tiller head for a Galilee? TominBC Gear & Maintenance 0 01-30-2001 12:38 PM
