Old 11-25-2010
Blitz - 34'Seidelmann
kolbn is on a distinguished road
Haylards in mast crisscrossed
For years I've wonder if this is correct or has any advantage: My halyards cris-cross in the mast. My main haylard enters the forward slot in the mast and the headsail enters the aft slot on the mast resulting in the crossing of the lines. Does it make sense?
Old 11-25-2010
Probably a mistake...It would be better if they didn't cross each other in the mast, since there is the possibility that they can chafe against each other.
Old 11-25-2010
Gary M's Avatar
Gary M is on a distinguished road
Yep probably not a good idea to cross your main and jib halyard.
It is common however to cross your spinnaker halyards since if you are launching on say the port side you will have a crew member hoisting at the mast on the starboard side, the high side as it is much easier.
Old 11-25-2010
SimonV's Avatar
Wish I never found SN!
SimonV will become famous soon enough
What it does is help stop the anoying slap/banging inside the mast.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location Brisbane Queensland
DELIVERY SKIPPER
What is a Deck-stepped mast and keel-stepped mast djr3203 General Discussion (sailing related) 11 12-25-2009 08:24 PM
How to secure steaming light to mast with halyards inside mast. Eihli Gear & Maintenance 7 04-14-2009 03:11 PM
Spinlocks Mast-Pro Harness for going up the mast? T37Chef Gear & Maintenance 12 04-12-2009 01:43 PM
Deck Stepped Mast or Keel Steeped Mast??? tbeargladd General Discussion (sailing related) 36 11-14-2007 08:07 AM
Mast leaks on keel stepped 52' mast mikeedmo Gear & Maintenance 5 06-27-2006 01:05 PM
