11-26-2010
Yes, but running the coax cable up the mast is going to suck.
Difficult but not impossible. Chances are you're going to have to make off the terminal/connector end at the mast head too (not too difficult, but everything is more challenging in a bosuns chair) otherwise you'll be drilling massive holes in the mast.
You'll have much better luck pulling the coax through with a messenger line, and if you already have internal halyards it's really going to be a challenge to avoid crossing those halyards. The other issue with doing it this way will be the difficulty in restraining the coax so it doesn't slop around and get noisy with motion, esp at anchor.
So, as SD so succinctly put it.... it's gonna suck  but with patience and a bit of luck you may succeed. (and a GOOD bosuns chair or at a mast tower)
1984 Fast/Nicholson 345
