Old 11-26-2010
costaricanwannabe is on a distinguished road
code zero vs 150 genoa
My Cal 39 came with two headsails - a working jib (about 110) and a 150 genoa. The 150 genoa was bought used by the previous owner but it has some problems and I am thinking about replacing it. Some of my friends have suggested a Code Zero. My question is, can I use a Code Zero most of the time, as my primary headsail? In other words, can I just put it on the roller furler and use it (for cruising, not racing) effectively in most conditions? My main cruising ground is the Chesapeake Bay. I imagine using the Code Zero at all times during light to moderate winds, then furling it and using the staysail if the wind really blows hard. Can my existing roller furler handle the Code Zero?
Old 11-27-2010
capecodda is on a distinguished road
code 0
I don't know if this will work for you, but the setup we have includes a 110 jib plus a code 0. The jib is on the furler all the time. The code 0 is on a wire luff and has a furler always attached while rolled up in the bag (like a snake). A number of companies make furlers that work this way, furling around the wire luff. In light air we hoist snake in front of the jib (our rig is fractional so there's room), and then unfurl at our leisure. If the wind pipes up, we furl the code 0, unfurl the jib, and keep going. We drop the snake again, at our leisure, mostly back on the hook at the end of the day.
I asked the sailmaker if we could just leave the code 0 up. If we wanted to do this, the sailmaker would add a UV protection layer which adds weight. Given how light the sail is, he recommended against this. We designed the sail so that at about 12 knots apparent, it's time to put it away. The good news is, you can sail very well in very light air with this setup.
Again, I don't know if this will work in your situation, but we really enjoy this setup and recommend it.
Old 11-27-2010
olgriz is on a distinguished road
Sounds like a great set-up…something I'd like to have also. What is the brand of the code 0 furler you use?
Old 11-27-2010
davidpm's Avatar
davidpm is on a distinguished road
Originally Posted by capecodda View Post
I don't know if this will work for you, but the setup we have includes a 110 jib plus a code 0. The jib is on the furler all the time. The code 0 is on a wire luff and has a furler always attached while rolled up in the bag (like a snake). A number of companies make furlers that work this way, furling around the wire luff. In light air we hoist snake in front of the jib (our rig is fractional so there's room), and then unfurl at our leisure. If the wind pipes up, we furl the code 0, unfurl the jib, and keep going. We drop the snake again, at our leisure, mostly back on the hook at the end of the day. =
Can you jibe the boat with the code 0 out or do you furl, jibe then unfurl?
What about sheets for the code 0 are they on deck at all times so you have two sets of sheets out all the time?
What model furler are you using for the code 0?
Old 11-27-2010
mitiempo's Avatar
Jibing would work for the code 0 as long as the sheets are led outside the forestay - just like a cruising chute. Coming about would be a furl unfurl affair though.
Brian
Old 11-28-2010
sheets, furler, etc
All good questions. When we built this boat, we discussed many of them at length as I was worried about the same issues.
We choose a Schaefer furler. I have 2 furling lines setup at all times. One goes to the jib furler, the other terminates in a figure 8 knot for the Code 0 on the ready. When I hoist the Code 0, part of the exercise is to attach the Code 0 furling line to the code 0 furler.
I leave the sheets on the Code 0 in snake mode in the bag. I lead these aft, and have a second set of blocks for the sheets, so I can leave the jib sheets lead as well. We put a cleat conveniently located near the primaries to store the sheets for the sail not in use.
When both sails are hoisted, it looks a lot like a solent rig, with the 2 sails only inches apart. If you want to tack, you do need to roll up the code 0. Of course you can tack the jib conventionally because it's on the inside.
If you want to jibe the code 0, you can without rolling it up if you lead both the sheets in front (like you might do to make a cruising chute jibe). The sail effectively flags out in front of everything.
All of this depends on the rig allowing you to place the code 0 in front of the jib. A fraction rig makes this easy, but I think you could do it with a removable sprit of some sort, even if your jib was all the way forward. In our case we had the boat builder make an extra long anchor roller, with a place to attach the code 0 forward. There also has to be enough clearance up top, which again a fractional rig makes easy, but maybe a spinnaker halyard would allow for this.
There are other furlers that might be better depending on your preference. Lots of the furlers for this purpose are continuous line furlers (I think Facnor works this way). When we looked at these, we imagined having to go forward to work the continuous furling line, although in retrospect I'm not sure this is actually true. The Schaefer furler is sort of a small conventional drum where the line accumulates when unfurled. It is nice for a cruiser anyway, to be able to roll up the code 0 when the wind comes up without sending anyone forward.
When we built the boat, we decided to build it with the code 0 setup, and wait to see if we wanted a cruising chute in addition. After living with this for 2 seasons, I have not been motivated to add the cruising chute to the inventory. Rolling is easier than socking. It reaches pretty nicely including in quartering situations. Again, we are cruising sailors, and your situation and preferences might be different.
Fitting an A-Symetrical/code zero? luskin General Discussion (sailing related) 13 12-02-2010 11:13 AM
Code Zero configuration CodeZero General Discussion (sailing related) 4 08-04-2009 07:04 PM
How useful is code zero/gennaker furler? sailbear50 Gear & Maintenance 1 03-23-2008 06:29 AM
Facnor Code/Asymmetrical Furler GeorgeB Gear & Maintenance 13 11-20-2007 06:29 PM
Spinnaker/Asymetric/Code 1? Harpooner General Discussion (sailing related) 1 06-12-2001 09:37 AM
