-   -   Remotron heater - manual request (http://www.sailnet.com/forums/gear-maintenance/70290-remotron-heater-manual-request.html)
KBuckley 11-29-2010 12:14 AM
I have an early '80s heater in my boat. The model is Remotron from AB Thermotron in Sweden. It is a propane forced air heater. The company still exists but has moved on to other products. Apparently they stopped making these 20+ years ago. Does anyone have a manual they would be prepared to scan and send me? I have not been successful in tracking one down on the web.
The unit still works but it is intermittent in that it occasionally shuts off for no reason, or will not shutoff if the flame does not light. I have checked the furnace box and it is still intact and has a few more years life in it. There is a photoresistor that acts as a flame sensor and there is an over temperature switch. They are connected in series and the resistance does change depending on whether the flame sensor sees light or not but I have not yet been successful in identifying what resistance values are present when the unit is responds correctly to the signals versus when it does not. I am trying to decipher whether the sensors may be bad or the electronics. Unfortunately the electronics are epoxy potted and not likely accessible.
Thanks in advance,
Ken
John Gerard 02-15-2013 12:32 PM
Re: Remotron heater - manual request
I am repairing /overhauling a recently purchased Broom30 which has a non working Remorton space heate previous owner had no interest in getting it going and there was no literature supplied with it. Am wondering if u got yours going well again . Any information including instruction manual would be appreciated.. I cannot source a plug replacement . Spec on plug is ZK 14-9-38. UK. The machine no. apparently is 30151, Another mark on the machine is SKARSHAMN r
KBuckley 02-15-2013 04:59 PM
Hi John,
I was not able to track any information down. I ended up removing the old controller entirely and making a new one myself. I used an Arduino microcontroller. It is probably as safe as the original control module but certainly not "failsafe". I would never run it unattended or while sleeping so I view this as an interim solution.
As to the plug - I assume you mean the spark plug for the ignitor. I just cleaned and reused the existing plug. It only sparks for a short time on start up and the quality of the spark is not particularly important to function. Any plug with similar dimensions of projection into the flamebox would be fine.
What state is yours in? Once I established that the flamebox and surrounding body were still sound I was prepared to have some fun getting it going again. If there is any doubt as to the integrity of the flamebox you should remove it - it is just too dangerous.
Ken
jpbecton 03-18-2013 09:59 AM
Originally Posted by KBuckley (Post 990672)
Hi John,
Ken
hi ken was just wondering if you could send me details of how you made up the controller as i have the same problem as you thanks jpbecton
KBuckley 03-18-2013 04:10 PM
Hi jpbecton, I would be happy to provide more info. Currently I am away and only have my cell phone for internet. I will send more info in a couple of weeks. (Just pm me if it takes longer than that.)
Ken
paul323 10-30-2013 04:51 PM
Coincidentally I have the same symptoms, and would also be interested in your fix...the weather is getting cooler, and it would be nice to have a functioning heater...
KBuckley 11-01-2013 12:01 AM
1 Attachment(s)
Here is a poor quality scan of the schematic of my controller. If you send me a PM with an email address I can send you a legible version and the source code I wrote for the Arduino controller.
Google "Arduino" to learn about the controller - a simple, cheap, open source microcontroller.
Ken
boatpoker 11-01-2013 12:36 AM
Don't tell your insurance company you are using one of those in a boat.
guillaume 02-05-2015 02:30 PM
I have a '78 vintage Remotron heater that I mounted in an Alaskan camper at that time and used very little. It has been sitting since '79 and is essentially new, old stock; original box and all. All parts including thermostat and instructions if anyone is interested as a replacement or for parts.
jada 08-24-2015 05:48 AM
hi Ken Buckly im new to this i have a REMOTRON gas heater and was reading your piece regarding the igniter. ive got the same problem and wondered if you still have a circuit diagram for the one you designed, if so could you please send a copy so that i can make a unit up, im good with me hands on but havent got a clue when it comes to electronics design thanks very much in advance ray
