11-29-2010
Most of the urethanes aren't really designed for the type of abuse they get on a boat. First, the UV levels on most boats is higher than on terrestrial uses, since there is a lot of reflected UV off the water and such. Water reflects about 50% of the UV light hitting it. Even the ones with UV protectant additives aren't very durable when it comes to marine use. Then there is the physical abuse that marine woodwork often gets subjected to—nicks, scrapes, impact, constant handling—all of which can break the surface coating and allow moisture to get beneath the finish. Then there is the weather that marine woodwork is subjected to, which is often harsher than what you'd see on land. Marinas are often more exposed to the weather than residential areas are.
Originally Posted by lapworth
So are you all telling me that these out door urethanes with uv protection are no good?
