11-30-2010
If the temperature drops below 50 degrees during the curing cycle, it's probably going to get screwed up. A lot depends on the actual temperature and humidity.... but lower temperatures are going to extend the time the paint takes to harden and cure properly. Anything below 50 is also risking problems with condensation on the painted surface causing chalking of the paint's finish.
If the temperatures are much below 50 degrees, you may have to wait an extra day or so to allow the paint to cure properly before applying another coat of paint over it. If you paint over the partially cured paint, you're going to run into serious problems relatively shortly, since adhesion will be a problem for both layers.
There are some more modern formulations of paint designed for colder climates that can be applied in temperatures as low as 35 degrees, but I don't believe Kilz is one of them.
I'd also recommend only applying the paint in the middle of the day, when the temps are at their highest, so that the paint has sufficient time to start curing before the temps drop too low. Heating the cabin may not help, because uneven temperatures may result in mixed states of cure for the different temperature regions.
