12-01-2010
Also, carbon fiber masts can have serious issues with metal hardware attached to them. The graphite is more noble than any of the metals and leads to galvanic corrosion cells forming unless care is taken to isolate the metal from the carbon fiber.
A ding is a small dent or scratch caused when a mast bumps into something else. Scratches can be particularly bad for laminate masts.
Also, for a cruising boat, an aluminum mast makes more sense. It is easier to repair/replace an aluminum mast than it is a CF one, especially in more remote areas. Also, CF has issues with lightning—far more so than Aluminum.
