12-03-2010
Originally Posted by scottyt
a lot of people will recommend doing a high pressure fitting up top, then you can bring it to the boat and cut to fit. the reason for this is you can not easily check the fitting at the top to see if it is loosing. you can get a cable with the press done up top easily and cheaply by mail order.
I believe what ScottyT is trying to say is that to save money, a lot of people, including myself, will recommend you get a swaged terminal at the top of the rigging, since swages tend to fail at the deck more than mechanical fittings do, and use a mechanical fitting on the bottom, so you can cut the rigging to length and terminate it without specialized tools.
The problem with swaged fittings at the deck level is that a swage is effectively an inverted cup, and it becomes a failure point...mechanical fittings can be inspected, disassembled, etc.
