Blogs
User Name
Old 05-18-2003
salecm salecm is offline
salecm is on a distinguished road
Blisters
I''m considering purchasing a 1979 Morgan Out Island 41. Broker tells me that owner''s survey has revealed blisters. If left untreated how big a deal is it? Found a web site that suggested $300 to $400 per foot of waterline to correct this problem. How long can I postpone repair?
Old 05-18-2003
jbanta jbanta is offline
jbanta is on a distinguished road
Blisters
Postpone Blister repair? You can''t, you have to take care of them now!!. A Blister is water penetrating the bottom of your boat. If left uncared for you could lose the whole hull. Blister are nothing to fool with. If you have any confidence working with glass you can do this job yourself.I had three first time I pulled my boat. I dug out all the effected area sanded it down smooth leaving a cupped area to lay in new glass. It is a big job and I understand why a $300 to $400 a foot figure is given. But do it yourself or pay but it has to be done and has to be done now. When it all repaired don''t let it happen again use a top grade epoxy paint and solve that problem forever..
Old 05-19-2003
ABullard ABullard is offline
ABullard is on a distinguished road
Blisters
Blisters are really not the problem everyone makes them out to be. Most of the hype was created by companies selling repair regimes. Water is always flowing in and out of your gelcoat. Blisters are just that, a pocket of water between the gel coat and the glass. The glass is not affected by the water, as long as it is sound.
In reality it is simply a image thing.
If you don''t believe me ask a Surveyor. I currently have about 12 blisters on the bottom of my boat and when refinancing neither the bank or insurance company cared one bit about the blisters. Why, they don''t affect the structural soundness of the boat. Maybe the resale value for cosmetic reasons, but not the sea worthyness of the boat.
The best approach is that every time you do a bottom job, fix the worst blisters, budget considered and don''t worry about the rest. Over time you may solve the blister problem without breaking the bank.
Tony
Old 05-19-2003
Blisters
Ok, When the hull starts getting soft and you can just about push you hand thur the hull tell me it''s not a problem. Left uncared for thats what happends. I still say take care of them NOW. And use the epoxy and rid yourself of blisters forever.
Old 05-19-2003
Jeff_H's Avatar
Jeff_H Jeff_H is online now
Moderator
Jeff_H will become famous soon enough
Blisters
Actually there are a variety of causes for blisters and in most cases leaving them alone greatly increases the likelihood of needing a more serious repair. The most common form of blistering occurs when water reaches the by products of the particular thermo-chemical reaction that occurs in some kinds polyester resins. This reaction produces acids that attack the bond between the fiberglass and the resin in the laminate. In doing so the blisters are able to expand deeper into the laminate by traveling down the surface of fiber bundles in the laminate. Over time this can greatly weaken a hull.
On the other hand, Tony, a dozen or so blisters is nothing to worry about, assuming that you seal them. You also do not say where the blisters are occuring. It is posible to have blisters between the gelcoat or barrier coat, and the laminate. In that case, the blisters are not structural but still should be addressed. I don''t know why you think this is hype but having been around cases where blisters were allowed to continue unchecked until the hull had pretty much delaminated through to the interior in large areas of the bottom, I assure you that it is not just an ''image thing''.
With regard to Jbanta''s comments, one minor point here, you do not want to use an epoxy paint to repair blisters as most epoxy paints are not really made to function as barrier. The best barrier coats are either epoxy resin or vinylester resins (there are advantages and disadvantages to both). In any case where the bliter extends into the laminate a repair with fiberglass and either epoxy or vinylester resin is warranted.
Old 05-19-2003
Blisters
I know I havn''t got the technical speak you seems to have. And yes when repaired my blisters and filled them back in with good glass I used a top quility epoxy resin barrier in six coats.. Maybe a bit of over kill but after repairing blister on my own I made sure I wouldn''t be doing it again...
Old 09-25-2006
GoLikeaFish GoLikeaFish is offline
GoLikeaFish is on a distinguished road
The one thing that scares the crap out of me about owning a boat is all of the FUD about blisters. Here are some good links concerning research on the problem:
http://www.cruisersforum.com/forums/...light=blisters
The main point I took away from this is that you need to keep your bilge dry.
I skimmed through this and may have misunderstood, but my impression is that blistering is more of a problem is warmer waters.
Question: Is a boat that spent its life in Northern California and northward less prone to blistering?
Old 09-25-2006
Fstbttms's Avatar
Fstbttms Fstbttms is offline
I don't discuss my member
Fstbttms is on a distinguished road
No. The only possible difference is that the cooler water temperatures may slow down any chemical processes, but the the underlying causes of blistering remain, regardless of where the boat lives.
"Clean bottoms are FastBottoms"
Old 09-25-2006
Fstbttms, I was hoping you'd chime in on this. Good to know that water temperature retards the problem, even if it’s a little bit.
My concern is with the type of blistering that threatens the structural integrity of the hull. In your experience, can you minimize the damage by keeping a dry bilge? (I’m sure no one would argue the benefits of a dry bilge, but its relationship to blisters may not be entirely clear.) Are there ways for a surveyor to detect “bilge neglect"?
Old 09-25-2006
camaraderie's Avatar
camaraderie camaraderie is offline
Moderator
camaraderie has a spectacular aura aboutcamaraderie has a spectacular aura aboutcamaraderie has a spectacular aura about
Go...Fish.....
Don't know where the dry bilge came from but the vast majority of blisters are caused by water outside the hull...not inside. Couldn't hurt to keep it dry but I've had several boats with wet bilges over the last 30 years and no blister issues associated with them.
Salecm...
I'd walk away from the Morgan if you have more than a handful of blisters to deal with. Too much time and $$ involved to fix properly and there are lots of boats without blisters out there. You can get a discount for the cost of repair...but not the time!
Display Modes
vB code is On
Hull Blisters jmorpeth Buying a Boat 6 10-21-2006 12:40 AM
1988 with blisters hrmacdonald2000 Buying a Boat 1 09-12-2004 05:51 AM
Boat with history of blisters gstraub Buying a Boat 12 12-02-2003 05:28 PM
GULFSTAR BLISTERS evanplauche Buying a Boat 0 02-18-2003 05:43 PM
Blisters islandive Buying a Boat 3 01-18-2002 03:51 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
