Best AIS receiver for the buck - Page 5 - SailNet Community
 1Likes
post #41 of 141 Old 12-16-2010
arisatx's Avatar
Pete:
SH has announced a new VHF AIS model, their Matrix 2150
Panbo: The Marine Electronics Weblog: Standard Horizon 2011, new everything!
Regards,
Ted
V42#186
s/v Little Wing
arisatx is offline
post #42 of 141 Old 12-17-2010 Thread Starter
Beneteau 411
Originally Posted by arisatx View Post
Pete:
Thanks! Can anyone summarize what noteworthy features the 2150 includes not provided by the 2100?
Pete
prroots is offline
post #43 of 141 Old 12-17-2010
Pete
from what i read the main update is to the NMEA setup so all communication with the chart plotter can happen over just one port. Also 2150 allows selecting True or Magnetic bearing display and may be has a couple of other minor updates.
There is no NMEA 2000 but looks like that is not a big deal. I'd rather have old nmea at a reasonable price than outrageously expensive n2k unit (like garmin 300 VHF AIS which costs at least twice as much)
zibadun is offline
post #44 of 141 Old 12-18-2010 Thread Starter
Beneteau 411
I've read what I could find on the gx2150 and still don't understand the significance of the NMEA upgrade. As far as I knew the gx2100 could be interfaced with the Garmin 441s without problems with both gps location and DSC on a single NMEA port. The AIS data from gx2100 to 441s requires a second port, but that seems to remain the same. Does anyone understand exactly how the NMEA has been improved with an example of what benefit it offers? Thanks
Pete
prroots is offline
post #45 of 141 Old 12-18-2010
arisatx's Avatar
Pete
Pete:
Tim Flanagan over at Navagear shares some info here
Regards,
Ted
V42#186
s/v Little Wing
arisatx is offline
post #46 of 141 Old 12-18-2010 Thread Starter
Beneteau 411
This article attempts to explain the NMEA upgrade a bit better than the reference above:
New Standard Horizon GX2150 VHF/AIS/loudhailer: A winner, for sure
This seems to be the most enlightening part of the above article:
All the NMEA data between the Matrix unit and whatever chartplotter you might own is aggregated into a single high-speed port.
As I understand it, both the gx2100 and gx2150 have 3 types of NMEA data: gps input, DSC output, and AIS output. Apparently the two outputs can now be combined together by selecting the same Baud rate for each. This was not possible before since DSC out ran at 4800 Baud and AIS at 38400 Baud. Can anyone agree or disagree with this interpretation? Of course, the chartplotter must be capable of interpreting both DSC and AIS on the single NMEA port if my assumptions are true. My guess is that this is a firmware upgrade which did not require a change to hardware. If true, I wonder if it's possible to upgrade existing gx2100's? Looks like I have more questions than answers!
Pete
prroots is offline
post #47 of 141 Old 12-18-2010 Thread Starter
Beneteau 411
Pete:
Looks like we were posting at exactly the same time! That's the same reference I cited above. Thanks
Pete
prroots is offline
post #48 of 141 Old 12-18-2010
Pete
this is my understanding as well - it has a high speed bidirectional COM port which receives gps position and transmits aggregated ais/dsc info.
zibadun is offline
post #49 of 141 Old 12-18-2010 Thread Starter
Beneteau 411
Thanks. The upgrade does not affect me since I had planned to go with the Garmin 441s which has two NMEA ports. Guess it would be a welcome addition to those with older one port chart plotters. I wonder if those older chart plotters can pull both DSC and AIS data off the single port?
Pete
prroots is offline
post #50 of 141 Old 01-01-2011
TakeFive's Avatar
Pete
One other case would be people who have a separate depth sounder that they want to feed into the plotter by NMEA. Now you have three inputs (depth, DSC, and AIS) with two available inputs (like with the Garmin 640 that I am considering), so two of them need to be combined.
If the GX2150 multiplexes the two (and I'm not 100% sure it really does due to some of the weasel words in the descriptions), it could make things a lot easier and may avoid the need to buy a multiplexer.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
Low buck projects- Let's see 'em! bljones Gear & Maintenance 1559 09-23-2016 12:03 PM
Low buck bow thruster?? wildcard Gear & Maintenance 53 12-11-2014 04:56 PM
Best battery monitor for the buck prroots Electrical Systems 18 03-10-2014 02:16 PM
Best Upgrade for the buck? SCoffshore Irwin 6 07-18-2008 06:00 PM
Dahon folding bike for a buck thorJ30 Boat Review and Purchase Forum 0 02-24-2005 02:31 PM
