Like Tree1Likes
Old 12-04-2010
Beneteau 411
prroots is on a distinguished road
Best AIS receiver for the buck
I'm about to outfit a 34 foot sailboat for offshore cruising. It would seem that being able to receive AIS data would be a nice safety feature. The receiver should probably have dual receivers and have the ability to share the VHF antenna with the VHF radio antenna. Also, it should offer NMEA 0183 output as a minimum and perhaps NMEA 2000. Any suggestions on AIS receivers that offer these capability for a reasonable price. I intend to display the output on my laptop.
Pete
Old 12-04-2010
Why not get a Standard Horizon GX2100 VHF, which has an integrated AIS receiver in a fairly nice DSC VHF unit, with a small display for AIS data.
Old 12-04-2010
eherlihy's Avatar
Finally found the needle!
eherlihy is on a distinguished road
If a receiver only is what you want, then the Standard Horizon GX2100 will fit the bill...
However I would suggest that as long as you are going to all the trouble of installing and the expense, you may as well install an AIS Transceiver. A Transceiver will allow other vessels to see you, as well as you seeing them.
Garmin has a nice unit, IIRC ~$600
ASA 101/103/104/105 Certified - Also certified in Recreational Marine Electrical Systems
Old 12-04-2010
Maine Sail's Avatar
Best receiver value is the Standard Horizon GX2100-AIS. Sends data to any GPS plotter as well..
Red ship is AIS from GX2100-AIS...
______
-Maine Sail / CS-36T
Old 12-04-2010
Beneteau 411
Red face
Thanks. I think that may be the way to go. I'm planning to purchase the Garmin gpsmap 441s. It appears that the gx2100 has 3 NMEA ports with 1 hi speed for ais output, 1 low speed input for gps, and 1 low speed output for dsc. The 441s has a Tx port 1 out, Rx port 1 in, Tx port 2 out, and Rx port 2 in. Any idea how you'd connect things so that both the gx2100 and laptop received gps data from 441s and both 441s and laptop received ais data from gx2100? Can the NMEA 0183 gps output of 441s be paralleled and sent to both gx2100 and laptop and likewise can the ais output of gx2100 be paralleled and sent to both 441s and laptop?
Edit: I do have a USB hockey puck gps which could easily provide gps input to laptop. That still leaves the question on paralleling the ais signal. For some reason, I'd like to share the gps signal from 441s (if possible) and save the hockey puck as a backup.
Old 12-04-2010
October Moon B43
MJBrown is on a distinguished road
Check out the ICOM MXA-5000 receiver. Picks up both A and B signals, uses the exisiting VHF antenna and is easy to connect. Picked one up last year (2009) after the Annapolis Show for $415 from Defender. Works well with my E120.
Old 12-04-2010
RhodesSwiftsure's Avatar
RhodesSwiftsure is on a distinguished road
Second Vote for MXA-5000
I've found the MXA-5000 to be very good unit. One really nice and often overlooked feature is that if you wire a GPS _into_ it as well, then it will repeat GPS and AIS nmea data out on a separate PC serial line. I have this wired to a bluetooth serial dongle, and so any laptop onboard can pick up the bluetooth serial connection and see realtime position and AIS data. Very handy (now if only Apple would put a non-crippled bluetooth stack on the iPhone and iPad).
"The slower we moved, the more we seemed to see."
- LP
Old 12-04-2010
jrd22's Avatar
Courtney the Dancer
Does the GX2100 just use the existing VHF antenna cable? If so it seems like a no brainer and it says that my RAM mike will connect to it too.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 12-04-2010
night0wl's Avatar
night0wl is on a distinguished road
There are reasons to want receive only...privacy for one! Have you seen those websites that plot ais tracks online? They have prior 30 days of data *OR MORE*!!!! I for one do not want my ais breadcrumbs to be available for all to see.
For receive only, I agree with the standard horizon matrix. But for me, this meant not only a new VHF, but also now a new ram mic and cabling...it became a $1000 project. Too much.
So I'm investigating the newest ACR dual channel nauticast from on sale for sub-$200 at defender. Getting a dedicated whip VHF antennae and mounting it to the bimini. Redundancy of antennas is a good thing anyway, and can't beat the price.
S/V Jendai
Beneteau 343
Old 12-04-2010
Maine Sail's Avatar
Yes all you need to do is connect the NEMA, power, VHF antenna and the RAM if you have one..
______
Low buck projects- Let's see 'em! bljones Gear & Maintenance 358 3 Days Ago 12:33 AM
Best battery monitor for the buck prroots Electrical Systems 17 12-05-2010 03:09 PM
Low buck bow thruster?? wildcard Gear & Maintenance 23 01-11-2009 08:57 AM
Best Upgrade for the buck? SCoffshore Irwin 6 07-18-2008 06:00 PM
Dahon folding bike for a buck thorJ30 Boat Review and Purchase Forum 0 02-24-2005 02:31 PM
