12-05-2010
1968 Pearson Wanderer 30
Originally Posted by St Anna
Are you referring to gaskets to lash a mainsail?
If not, then please ignore my rambling on.
I run an 8mm stretch cord (occy strap) from tack to clew and back. I have 5 clips in 5 sections, partitioned by snipped off cable ties. Each clip is on the same side (stb).
When the sail is dropped into the lazy jacks, I reach over the bunched up sail for the first clip, stretch it over to clip onto the stretch cord on the other side. I now have 5' of bagged' sail. I move aft and repeat until all of the sail is wrapped up.
This system, I have nothing to carry, tie or worry that I may collect a hook in the face if I let go.
The following photo shows the occy cord behind the cat. In this photo, I was hindered in tidying the sail because of the rotten cat jumping up. So please ignore the cat, we try to!
http://i665.photobucket.com/albums/v...a/minke019.jpg
I'm trying to make sure I'm envisioning this correctly. Can you clarify, or maybe provide another pic or two? Sounds like a pretty slick setup.
Thanks
- Bill T.
- Richmond, VA
"Twenty years from now you will be more disappointed by the things you didn't do, than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."
- Mark Twain
