Old 12-07-2010
F4d3d's Avatar
F4d3d is on a distinguished road
Adequate Zincs
Hello All!
I'm dropping a new-to-me sailboat (a thread on this soon!) into the water tomorrow. There is currently only one old zinc on the prop shaft, and no others anywhere else on the boat. The strut was just replaced with a newly crafted stainless steel one, and I never saw the old strut, so I'm unsure if there was a zinc on it or not.
How do I know the appropriate amount of zincs to use, and if one should be added to the strut?
Thanks!
Old 12-07-2010
DulceSuerna's Avatar
DulceSuerna is on a distinguished road
Forgive my typing, (rum)
I have a zinc on the shaft, one on my rudder, and one in my heat exchanger ( I replace every 2 months), it is a small pencil zinc, and dissolves fastly. Without a doubt replace the old zinc with a new one on the shaft.
My 2 cents.
Old 12-07-2010
jackdale's Avatar
jackdale will become famous soon enough
Agree with DS.
One on the prop shaft and and IN the heat exchanger, at least.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 12-07-2010
paul323 is on a distinguished road
Personally I have 2 on the shaft, and the pencil in the heat exchanger.
I'd also suggest you check it/them regularly, at least initially. I am in a 'hot' marina, and 2 zincs only last 6 months (!!!). I have just installed a galvanic isolator - it'll be interesting to see of it helps.
Old 12-07-2010
A couple of zincs on the shaft, the strut zinc is probably overkill.
Congrats on the boat.. where will she live? Pics required, of course!
1984 Fast/Nicholson 345
Old 12-07-2010
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
...the strut zinc is probably overkill.
The only reason to install a zinc on the strut is if there is evidence of corrosion. Otherwise, leave it be. I have seen struts break where they are drilled for zincs. Two on the shaft may not be strictly necessary but is good insurance.
"Clean bottoms are FastBottoms"
Old 12-08-2010
F4d3d's Avatar
Thanks for the replies everyone. We'll put two new zincs on the shaft, and one in the heat exchanger. I may have some questions about the heat exchanger zinc tomorrow after I have a closer look at it.
An introduction thread and pics are on the way soon! We're planning to sail her to French Polynesia in a few months, so she won't have a permanent home any time soon.
Old 12-08-2010
Originally Posted by paul323 View Post
Personally I have 2 on the shaft, and the pencil in the heat exchanger..
My shaft is just too short to fit 2 or I would of, wait that doesn't sound right does it
Old 12-09-2010
boomvangdc is on a distinguished road
This article might be helpful: Zincs: Can you have too much of a good thing? | Daily Sailing News from North American Sailor.
In reference to the comment about being in a "hot marina" and my own experience (using a freshwater zinc in saltwater - not a good idea), I recommend having you or someone else take a look at the zincs periodically while the boat is in the water to see how quickly they are depleting.
Old 12-09-2010
I'd point out that if you even suspect your marina as being a "hot" marina, don't dive on the boat in the marina...anchor out someplace away from any stray currents to check the zincs...
Zincs Neicy Gear & Maintenance 7 04-24-2012 08:02 AM
Arpege zincs? lawsonmitchell Dufour 0 10-03-2009 02:02 PM
Where are the Perkins 4-108 Zincs?? TSPMorgan383 Diesel Engine Forum 5 07-14-2009 12:33 PM
Perkins 4-107 Zincs Alden68 Gear & Maintenance 0 05-19-2007 07:40 PM
Fish Zincs, Pencil Zincs and stray current gcalahan Catalina 0 04-18-2007 08:27 PM
