12-09-2010
Can't really run any of the A/C units off of the battery banks, unless you've got a truly massive battery bank... which is unlikely. They need to be run using a generator or shorepower.
You'd be better off asking someone with a lot of A/C experience about the problems, but areas I've seen are the heat exchangers, the compressors and the raw water pumps.... Don't know the Cruisair units specifically, since most of the work I've done on them has been with Mermaid units.
At 24 years old, they're probably about due for replacement.
