12-10-2010
As long as it works, it's repairable. You're not rowing competition. Don't glass them, varnish or paint them. Epoxy is best. I've had bad experience with the little tubes from the hardware store, West is probably most used. Get a glue syringe to inject the epoxy into the split. Line for clamping should work well, even duct tape. If all this becomes too expensive, try Titebond III. Finally, ask on the Woodenboat Forum, you'll get lots of replies.
