Old 12-10-2010
ukrsindicat is on a distinguished road
Intake/ outflow valves
Good morning everyone!
My head intake and outboard hull fittings have no valves. I guess previous owner, believed in luck and his plumbing skills to keep the boat afloat.
Well, its time to get something done about it.
I am know that I need 90 degree ball valves. I was planning on diving under and pushing two Tru Plug cones in the intake and outflow of my hull fittings to prevent water from getting in while I am working out it. However, I am not sure how to glue those ball fittings on. What materials should I use? What precautions to take, etc.
Any help would be appreciated!
Here are photos of the current set up
Picasa Web Albums - Yuriy Tymoshenko - hull fittings
Yuri
Old 12-10-2010
justified is on a distinguished road
What is the material coming threw the hull? Looks like Glass or glassed over. You are going to need to mount the new valves to a structure. Consider glassing in a mounting plate around the existing material and the cut flush to the top of the mounting plate and then attach your new valve like any other.
looks very scary.
Peter
"Frayed"
Old 12-10-2010
tommays's Avatar
Thats some scary plumbing and i would fear doing much while its in the water
I would work on going to seacocks for long term safe shut off
Replacing Thru-Hulls and Seacocks Photo Gallery by Compass Marine at pbase.com
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Gate valves and why we don't use them... sailboy21 Gear & Maintenance 28 11-12-2008 10:55 PM
Adjusting the valves Dferr Gear & Maintenance 1 06-23-2006 11:42 PM
ANTISYPHON VALVES GASTONFMARTIN Gear & Maintenance 0 04-05-2005 03:43 PM
Y valves drynoc Gear & Maintenance 0 01-01-2004 02:34 PM
Volvo intake valves for MD6A not avaiable from Volvo Larrys Pal Gear & Maintenance 5 03-27-2002 05:58 AM
