Old 12-10-2010
QuickMick's Avatar
QuickMick is on a distinguished road
Pergo laminate
i was thinking of using pergo for flooring and was wondering if anyone has used this. It actually looks pretty good, seems to be light and have good moisture res. props.
Obviously its not teak plank, and will probably make some people hurl. hey, where did the hurl smilie go?!?! but it seems to be an adequate substitue that would be fairly easily installed over existing flooring/bilge access panels.
im even considering using it to cover over the aged laminate galley counter...
comments, as always, appreciated.
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 12-10-2010
anemoneii is on a distinguished road
I have pergo in my kitchen, every time water lays on a seam it starts to delaminate in that area. Pergo has no place where water could be present.
Old 12-10-2010
Minnewaska will become famous soon enough
Pergo will resist water from the top very well, but soaks it like a sponge from underneath. I doubt it would be a good idea for marine use.
I installed 1000sf of it in a basement with no water, just slightly damp. I even used plastic underlayment as instructed. It all buckled.
edit: bucking is not the right word for it. Each seem pinched up, the entire floor did not have expansion pressure. Suffice it to say, it looked awful.
Old 12-10-2010
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
I agree with anemoneii, I've replaced 100's if not 1000's of sq ft of this type of flooring that was used in Bathrooms, service rooms and Kitchens, not really moisture friendly
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 12-10-2010
Allanbc's Avatar
Allanbc is on a distinguished road
What about bamboo flooring?
"When in command, command." -- Admiral Nimitz
Difference between a power boater and a sailor out on the water: A power boater is going some place special, a sailor is already there.
s/v Zotz 1981 Pearson 365 Ketch Hull #375
Old 12-10-2010
Bamboo flooring is very heavy; so compressed it actually doesn't float. However the weight's in a pretty good place!
A friend redid the sole on his Ericson 33 and it's standing up well and looks great. As a solid wood product it's going to be a lot better than the 'pergo' laminated style floor as mentioned above. On the pricey side, relatively speaking.
1984 Fast/Nicholson 345
Old 12-10-2010
Jurgy is on a distinguished road
Take a look at "Plasteak" - via Google
Old 12-10-2010
QuickMick's Avatar
huh, thats funny, i knew a girl with some 'plasteak' parts once...
Quinn McColly
Yacht Broker
Old 12-10-2010
And even though those parts weren't made of teak - I'll bet you still enjoyed them .....
Old 12-10-2010
LandLocked66c's Avatar
Sunsets and Warm Beer....
LandLocked66c is on a distinguished road
He meant a barbie doll.
1971 23' Oday Pop Top
S/V Frida
You can't steer a boat that isn't moving? Just like a life - P. Lutus
What do you get with laminate sails? MedSailor Racing 13 06-25-2008 07:19 AM
Possible new hull laminate material? jonlgauthier Gear & Maintenance 3 10-05-2007 11:24 PM
laminate cutting chuckg5 Gear & Maintenance 19 11-03-2006 12:32 PM
