Old 12-11-2010
dreuge's Avatar
Panhandle Sailor
dreuge is on a distinguished road
Rudder Post Grease
My rudder post has a screw on grease cap. The ones which are periodically tightened to keep the post well greased. Water pump grease is the recommend grease. It was more readily available in the early 80's, but now I can find only one vendor. What are good alternatives which folks are using? Or does anyone know of brand of water pump grease which is likely still to be sold locally?
Thanks for any input.
S/V Johanna Rose
Old 12-11-2010
newhaul's Avatar
islander bahama 24
newhaul is on a distinguished road
check with some of your local auto restorers that do model A and T vehicles they should have a supplier available or they may be willing to sell you some out of their stock.
Illegitimus Non Tatum Carborundum.
Old 12-11-2010
St Anna's Avatar
St Anna is on a distinguished road
You can use lanolin.
Old 12-13-2010
billyruffn's Avatar
billyruffn will become famous soon enough
I've used Lubriplate 130-AA for years on the recommendation of my boat yard for rudder bearings, feathering prop and windlass. You can buy a case of 12 10 oz tubes on the internet for around $60 or you can buy one tube in a good marine store for aroung $15. You can also get a "gun" that the tube will screw into to pump the grease where you want it.
Old 12-13-2010
HDChopper's Avatar
Needing Apehanger Helm
HDChopper is on a distinguished road
+1 for Lubriplate ..
There is no right way to do the wrong thing
Rudder bearing grease? KeelHaulin Gear & Maintenance 1 06-08-2010 10:24 AM
rudder post moonie5961 General Discussion (sailing related) 3 02-22-2009 10:32 PM
8.0B rudder post dorourke S2 5 12-09-2008 12:40 PM
I37 rudder post amsb Islander 8 12-02-2008 08:44 PM
rudder post jrwright Gear & Maintenance 2 05-14-2004 08:25 AM
