snapped coaxial cable for SSB - Page 2 - SailNet Community
post #11 of 14 Old 03-08-2011 Thread Starter
gosh, i am electrical-wiring challenged. wasn't aware of the difference between coax and the high voltage single conductor cable. what i really meant must have been the latter all along. so i bought new high voltage single conductor white wire for the part between the tuner and backstay and am going to do the replacement tomorrow. would need a ladder to do that. is there a special connector between this cable and the backstay? if so, can i use the existing one? thanks.
yzlian is offline
post #12 of 14 Old 03-08-2011
celenoglu's Avatar
As you increase the number of connections, the probability of discontinuity increases. Instead of using two male and a two way female barrel, look for a single barrel with cable connections on both ends specially manufactured for this type of connections. It is best to replace the whole cable.
celenoglu is offline
post #13 of 14 Old 03-09-2011
There is no connector used for the backstay. Run the high voltage cable using the same path the old one used. Once you get the wire above the bottom insulator you can use a UV stable ty-wrap to fasten the cable to the backstay. Put the ty-wrap about 6" above the insulator and leave about 10" of cable hanging loose above the ty-wrap. Then loop the wire back down and use a small stainless steel hose clamp to clamp the wire conductor to the back stay above the insulator. The cable where you stripped back the insulation will be pointing down. That way water will not run down inside the insulation and attack the wire. Do not try to seal the end with any goop. In these situations goop just holds in water and makes things worse.
Try to keep the wire 4-6" away from anything metal except for the backstay above the insulator. Also, try to keep it from where people will be tempted to touch it. When the SSB is transmitting you can get shocked or burned from this cable even though it is insulated.
Inspect the connection regularly and if the wire seems corroded then just cut off an inch and reattach. After a few years UV will destroy the outer insulation on the wire and you will repeat this whole process with a new wire. Nothing lasts forever at sea.
Regards,
Dan
Transmitterdan
1995 Valiant 42
transmitterdan is offline
post #14 of 14 Old 03-09-2011
Shakespeare makes a connector to rejoin the cable. It has a small needle in the middle the penetrates both cables and makes a positive connection without much work. You should run new when you have time and money. I bought one at west marine for $5.
YeahJohn is offline
ENgine Gauge Hold-Down Snapped Off - Now What? Bene505 Gear & Maintenance 19 04-15-2010 07:21 AM
Windless cable size, cable manufacture and battery type? SanDiegoChip Gear & Maintenance 25 02-19-2010 10:44 AM
Mast snapped 12/09/09 crane0730 General Discussion (sailing related) 4 12-13-2009 04:44 PM
through deck coaxial cable-what wonderful suprises await me, my deck and my drill? bwu Catalina 1 11-20-2006 01:06 PM
Chain Plate snapped Update. ktucker8 Gear & Maintenance 0 09-06-2006 06:53 PM
