12-12-2010
I would put audible alarms on the oil and temperature gauges. If you loose oil pressure on a diesel the bearings go out very quickly because of the high compression so get an oil pressure switch that triggers a horn or loud buzzer at a rather high pressure but below normal operating pressure. It will give an alarm when trying to start the engine, but shut up a few seconds after startup. Also get a voltmeter that reads about 8 to 16 volts, I am not exactly sure of the range as it depends on the manufacturer. The voltmeter should also be fitted because a dead battery means no engine and you would have to dock using sails only. It would be a good idea to practice engine out procedures anyway as several other problems could also leave a dead engine. Get an accurate voltmeter with marks for each volt. A digital voltmeter is best as they can be very accurate. Wire it into the on/off key for the engine, but also have a momentary button that will read voltage with everything off. If a battery sits for about six hours or longer with no charge or discharge, this is the resting voltage and it tells how much the battery is charged. At 11.9 volts it is dead, at 12.06 it is 25% capacity, at 12.25 volts it is 50%, at 12.45 volts it is 75% and at 12.65 volts, it is fully charged. These voltages will be higher when the temperature is really cold and of course lower when temperatures are high. The voltages above are at 68 degrees Fahrenheit. With the engine running for 15 minutes or so after startup the charging voltage should have reached the stable voltage necessary to charge the battery to capacity, which is 13.8 to 14.7 volts with 14.4 volts a good compromise. The lower voltage results in less erosion of the battery plates, but takes longer to charge. A voltmeter is also a good idea if you have solar panels.
