12-13-2010
Winterizing it is just good seamanship... puts points in the black box... and helps prevent Murphy from kicking your teeth in...
BTW, if the -50˚ stuff got diluted, the freezing temp for it goes up really fast.
Originally Posted by rmeador
Ok, I guess I'll go get a few more gallons... I was using -50 degree antifreeze. I can't believe it will ever get that cold. Even if it dilutes, I would think it would be fine. I was beginning to question whether it is necessary at all. The water where my boat is supposedly never freezes in the winter, and the engine has the cabin on one side, espar on another, hot water heater on another, and battery charger on the last side... it's basically surrounded by heat generating things. The only thing that would put it at risk would be a power failure.
