12-13-2010
I'm talking a short extension cord, plugged into a GFCI-protected outlet. Not an ideal solution in any way, but strikes me as a better solution than installing an outlet into the coaming box.
I'd also point out that this is supposed to be a temporary situation... since he probably won't have the Christmas lights up past the end of the month and is planning on replacing the refrigerator.
Originally Posted by hellosailor
sd-
Running an extension cord, oh, folks are gonna slam you for that.
Got to say I'd agree though, an AC outlet in the cockpit just seem like temptation for problems and a lot of work for the occassional need. I'd use an extension cord with a GFI built into it, and try to run the extension cord via a lazarette and make sure the other device was also plugged in, in the lazarette.
