12-13-2010
Good luck with that. while you can certainly do it...the mast on a 35' boat is a bit more complicated than you'd probably want to tackle as a complete novice. It is likely to have at least two sets of spreaders that would need to be installed, as well as all the sheaves for the halyards, tangs for the shrouds and stays, conduit for the wiring, gooseneck, exit slots, winches, etc.
Sizing the rigging, since you're building it for a known boat, wouldn't be too difficult.
Just curious as to what your motivation for doing this is? Is it to save money? Is it to learn about rigging the boat?
Also, do you have the mast, boom, etc., or are you really starting from nothing?
