Old 12-17-2010
micheck is on a distinguished road
Quick Release for a Life Raft Cannister
I have a Canister Life raft mounted on a cradle between the mast and the fore hatch; it is held in this cradle by an array of 1/2" lines that culminate in a standard loop quick release knot - I have attached a carbanier link between this quick release loop and release. Is this OK/stupid? Is their a better/more standard way ... Thoughts Charles
Old 12-17-2010
Is the life raft supposed to have a hydrostatic automatic release or not? Can you post a photo of the knot and carabiner?
I'm not a big fan of using carabiners on a boat, since most are made of dis-similar metals and have issues with corrosion.
Old 12-17-2010
jackdale's Avatar
jackdale will become famous soon enough
I attach a knife in a sheath to the liferaft or to something close by. It serves two purposes:
1) slash the cords holding the liferaft in place.
2) Slash the painter when the raft is deployed. I also carry a knive at all times.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 12-18-2010
1: No hydrostatic release
2: I appreciate your dissimilar metals and sea water thoughts
3: I like the dual purpose knife at the ready
Thanks - Charles
Old 12-18-2010
hellosailor's Avatar
Charles, a carabiner will not release unless there is slack. There should be no slack in the lashings holding down a life raft, it should be rock solid.
And the reason everyone uses fiber rope instead of wire or chain, is just what the others said: It can be cut. Whack, and it is broken. If your knife isn't big enough and sharp enough to cut the line in one shot, you need a bigger sharper knife, even a cheap $2 machete if you put a good edge on it.
If I may suggest, if you reserve one knife for keeping on deck for emergency use, you might want to cover the blade lightly in bees wax. That will prevent any rusting or dulling, without stopping any cutting.
stay sail quick release pc37howard Pacific Seacraft 10 10-12-2010 10:24 AM
odd ball life raft ? do you have a life raft? scottyt Gear & Maintenance 0 04-08-2010 11:54 PM
Quick Release - Snap Shackles Reddirt General Discussion (sailing related) 4 10-12-2009 04:08 PM
Life Raft sailing320 Gear & Maintenance 2 01-07-2009 11:12 AM
Opinion on Wichard Quick Release Shackle? labatt Gear & Maintenance 3 07-16-2007 12:25 PM
