12-18-2010
Using a percolator, french press or some other stove-powered coffee maker would make a lot more sense on your boat.
while it might take 450 watts to brew, most coffee makers have a warming plate that also uses energy. Given the fact that you don't have any real high load devices other than the coffee maker, I would highly recommend using a non-electric method of making coffee, some of which are quite good—like the Aerobie Aeropress—and making it much more likely that your small solar panel can keep up with your usage.
Without a full inventory of equipment and an accurate electrical budget, it is hard to say whether a 45 watt panel is going to be enough to keep your batteries topped off. I rather doubt it...but I could be wrong. If you had all LED based lighting, that would go a long way to extending your battery capacity and reducing your electrical budget.
