12-18-2010
Probably talking about heater, as he's mentioned perforating the hose, probably to heat the hanging lockers a bit.
Probably won't affect the installation significantly. However, you might consider running the hose to a piece of aluminum duct and then back to hose for the locker segments, so that you don't actually have to puncture the venting for the heater, but the aluminum duct would act as a small radiator when the heater was in operation, without really affecting the air pressure in the heater venting.
