Old 12-20-2010
Beersmith's Avatar
Sailing to surf
Beersmith is on a distinguished road
Need some opinions on old equipment - Refrigeration & Autopilot
In the process of rebuilding my boat I am uncertain if I should ditch some old equipment or try to keep it going. At this time none of these pieces of equipment are functional, and I had not bothered troubleshooting since I figured I'd try to salvage what value I could out of them by selling and upgrading. However, as the list of things I need to buy grows, I am further seeking to save a buck. Please tell me if I should keep it or ditch it. I am DIY all the way, so keep that in mind with your recommendation.
1. 1993 Seafrost SA-III (134A) Series engine driven & 120 volt refrigeration & freezer system. I would like a DC system, but have given the current one some thought. It is already set up, though I would like to give the boxes more insulation before cruising. I plan on cruising in the tropics, and I know that matters when choosing a fridge system. I am curious if this old system is worth keeping though.
I don't really like the idea of an engine driven system, I'd rather keep my batteries topped with solar and an good alternator and have a constant cycle DC system. Is that a good idea or should I seek to get this one working? Would this old system have any value to sell? Any particular units I should look at to buy? Since the system uses chill-plates, and they are already installed, would it be worth ditching the engine driven compressor and just buy a DC run unit to use with the existing set-up? If I have a DC unit, I question keeping the AC unit since if I were to be tied to shore-power I would be charging my batteries regardless.
2. 1983 Alpha 4404 Autopilot. I would like a windvane for my self-steering, but want some sort of back-up and for motoring. I figure I would get a wheel pilot, but this old beast is attached to the boat. There is a mechanical control arm, a cockpit control unit, and a compass unit. I wouldn't know where to begin to start troubleshooting this, but would be willing to give it a shot. If just one of the three parts needed replacing, would these old things be worth trying to get going?
All advice appreciated.
My boat rebuild/sailing blog:
Please read and provide comment to my entries!
Old 12-21-2010
Ilenart's Avatar
Ilenart is on a distinguished road
On my last yacht I had an old Bremar autopilot that worked occassionally. I discussed repairing it with the local marine electrician and there advise was not to bother. If you got the time / inclination I would spend a day or two playing with autopilot / fridge, however any longer and your time is probably better off spent working on other areas. Also the new units they now sell are a considerable improvwment / more reliable than 20 year old equipment.
Ilenart
Old 12-21-2010
Second what Ilenart said. Also, you need to consider if it is worth investing in an obsolete, discontinued unit.
Old 12-21-2010
Admirals fav target
NCountry is on a distinguished road
Everywhere I read they say ditch the engine driven refrigeration. The 12v dc on my boat is awesome and fairly efficient.
Both GOOD WORKING autopilot and windvane steering = one less person on each watch.
Cruise me!
Old 12-21-2010
Beersmith's Avatar
Sailing to surf
Thanks for the advice. I just think I needed that little nudge to get this old equipment off the boat. I am gutting it right now and these two systems are the next to go. I didn't want to begin disassembly if there was any hope for them.
Next question...do these old parts have any value to sell?
Old 12-21-2010
deniseO30's Avatar
Lies about her age
You could probably keep the evaporator/s and just use a new 12 volt condenser (per another thread) but the cost savings is not that great.
a dripless shaft seal should be on the list for that boat.. omg the water damage from the drip!
Old 12-21-2010
Jeff_H's Avatar
Super Moderator
From everything that I know about it those early seafrost systems were as good as they got. The engine driven compressors were able to quickly chill the cold plates and they were able to hold a chill for a very long time. This was one of the most efficient systems which were out there, and at the time were seen as the 'gold standard'. These were robust and reliable systems compared to the less expensive, lighter duty 12 volt systems that have become popular since.
I do not know your specific autopilot system, but again, many of these older systems were extremely robust and reasonably energy efficient. In the nearly 20 year since we have gotten used to having solar arrays and bigger battery banks than were popular at the time and so the emphasis was on efficient and reliable. But as I said, I don't know your specific system and of course have no clue whether the problem is minor (dirty contacts) or major (blown brain box).
But in any event, neither systems has any resale value.
Curmudgeon at Large- sailing my Farr 11.6 on the Chesapeake Bay
Old 12-21-2010
Beersmith's Avatar
Sailing to surf
definitely a dripless seal is on the list. Lots of water and associated damage in that engine room thanks to the leaky seal
Old 12-21-2010
ccriders is on a distinguished road
I don't know how good your refrgerator is, but you might think of it this way:
If you were moving to a Carribean Island for an extended period of time, would you move a 17 year old refrigerator there, especially considering the availability of replacement parts?
John
Old 12-21-2010
Beersmith's Avatar
Sailing to surf
John
very good point
finding equipment Teirst Gear & Maintenance 7 01-12-2009 08:08 AM
Plotting Equipment Jim Sexton Learning to Sail Articles 0 08-18-2001 08:00 PM
Plotting Equipment Jim Sexton Seamanship Articles 0 08-18-2001 08:00 PM
Plotting Equipment Jim Sexton Gear and Maintenance Articles 0 08-18-2001 08:00 PM
Used Equipment ageorgia Gear & Maintenance 3 03-17-2001 04:01 PM
