Your
SSB will require a good RF ground (counterpoise).
A good RF counterpoise system requires 100 square feet of grounded metal(s) below the waterline, and could consist of:
1. copper foil, below the waterline. Could consist of 3" wide Cu foils @ 3" apart (simulates 9" wide strip) running fore and aft. Fix the foil to the hull, using
epoxy, glue, etc.
2. metal water tanks
3. engine block
These all provide a "capacitive" couple to the water.
4. external ground plate
5. lead keel (external)
Wire & cable are useless RF Gnding materials.
Hope this helps,
Gord
