Old 12-25-2010
Michael K is on a distinguished road
Remote TillerPilot Location, Redeux
Quite a while ago I read here about someone who mounted a tillerpilot far from the manufacturer's recommendation of 18" forward of the rudder stock. Instead, he/she ran lines through blocks back to a more convenient location for the tillerpilot.
I failed to follow up later to see the anticipated pictures of that setup and now, for the life of me, cannot find the thread through the search option. I'd greatly appreciate if anyone can direct me to that thread or start afresh here.
Old 12-25-2010
The reason for the 18" mounting point has a lot to do with leverage and range of motion. Closer to the rudderpost, the autopilot loses a lot of leverage. Further away, it loses range of motion.
Old 12-25-2010
xsboats's Avatar
xsboats is on a distinguished road
I've mounted many tillerpilots in remote locations utilizing a Morse cable to make the connection to the tiller. As SD points out, the distance that the connection at the tiller is relative to the rudderpost is important to maintain. It is also important that the pilot be mounted perpendicular to the centerline of the boat. You can change the orientation of the pilot to port or starboard control in it's menu. I may have pics of one I mounted recently on a Dreadnaught 32 . I use one on my 50' Seabreeze to actuate a trimtab for self-steering.
Old 12-25-2010
I guess I was a bit unclear. According to what I read, the lines lead to the optimal point of 18" forward of the rudder stock. The other end of the lines lead to a remote point of choice and connect to the tillerpilot. This arrangement permitted someone to put their tillerpilot within easier reach than, say, the aft corner of a catamaran. I was simply hoping to see an example. The morse cable certainly is a good idea.
NAVICO Tillerpilot tp5000 jzlatar Gear & Maintenance 9 11-05-2010 10:33 AM
New Tillerpilot nickmerc Gear & Maintenance 3 04-02-2010 06:03 PM
Tillerpilot Behavior Irwin32 Gear & Maintenance 7 06-30-2003 07:22 AM
Icom Remote Mic Timm40 Gear & Maintenance 5 03-24-2003 06:46 PM
remote anchor alarm?? grumol Gear & Maintenance 0 11-21-2002 06:09 AM
