Old 12-27-2010
SailingWebGuy's Avatar
SailingWebGuy is on a distinguished road
USB GPS receiver
Hello!
I need to pick up a USB GPS receiver for my laptop. Anyone recommend a particular model?
I found a few that used magnets for mounting. Will it interfere with a compass?
Thanks!
My complete refit is taking completely too long!
  #2
Old 12-27-2010
galynd is on a distinguished road
I purchased a GlobalSat Bu 353 from Amazon. It was about $36. Works very well. have never lost satellites even inside. It does have a light magnet. I've heard of some pulling it out. I've not tried. Waterproof.
  #3
Old 12-27-2010
jackdale's Avatar
jackdale will become famous soon enough
+1 on the 353.
I keep it below away from the binnacle compass.
I have to start and close the GPS program, then start the charting software, MapTech. A little quirky. but it does work well.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
  #4
Old 12-27-2010
windward54 is on a distinguished road
I use a Canmore GPS logger. Plugs directly into your USB port, and even though there is no exterior antenna, I find it logs in when down below, in under 30 seconds. Powers off, and charges up off of the USB port. Although it is designed to be used as a logging GPS stick, the output is NMEA and is compatable with any mapping system. I use mine to provide a GPS signal to Airmail 2000 software.
Amazon.com: Used and New: Canmore GT-730FL-S USB GPS Tracker Stick Data Logger (Built-in Rechargeable battery, WAAS, A-GPS, 256,000 Waypoints, 65 channels, Windows XP / Vista / 7 Compatible)
  #5
Old 12-28-2010
JimsCAL's Avatar
JimsCAL is on a distinguished road
Originally Posted by jackdale View Post
+1 on the 353.
Good to hear the 353 works with Maptech software. My current GPS puck doesn't support Windows 7 64-bit so looking for a replacement. What OS are you using?
  #6
Old 12-28-2010
JimsCAL's Avatar
+1 on the 353.
  #7
Old 12-28-2010
jackdale's Avatar
I am using XP.
The 353 is actually a serial device that requires a usb-serial driver to work. Is that a problem with your current puck?
  #8
Old 12-28-2010
Thanks everyone! Just ordered the GlobalSat Bu 353. I'm gonna give it a whirl with PolorNavy when it gets here.
  #9
Old 12-28-2010
Sea Slacker
brak is on a distinguished road
I use BU 353 myself (so yes, PolarView/PolarCOM will work with it ), but also just ordered Canmore device (thanks for the pointer). I was looking for an inexpensive dongle-style USB GPS because in some situations I'd prefer not to have a long connecting cable (when used with a small netbook). Also found it really cheap ($30).
BU 353 is an excellent device, though - has been extremely reliable for me and provides a very accurate fix (i.e. in my personal use it has rarely been off by more than a few feet). Because it uses a common PL2303 chipset, it is supported pretty much on any operating system. I.e. it will be visible as a serial device on that system - the rest is up to the GPS/navigation software.
  #10
Old 12-28-2010
JimsCAL's Avatar
I am using XP.
Problem is lack of a 64-bit driver. Unit is a Delorme LT-20 which also requires a USB-serial driver. Delorme had driver that worked on my old XP laptop. Works with their software on my new laptop but customer service says no intention to develop 64-bit driver to permit supporting other software.
You may post attachments
You may edit your posts
Best AIS receiver for the buck prroots Gear & Maintenance 140 09-02-2011 03:06 AM
VHF Radio w. AIS receiver py26129 Gear & Maintenance 13 11-10-2010 12:08 PM
si tex gps receiver 20A mk11blue Electronics 0 04-25-2010 08:23 PM
SSB Receiver Snboard976 Gear & Maintenance 1 11-23-2009 09:54 AM
new PC/USB Navtex receiver! camaraderie Gear & Maintenance 13 06-25-2007 01:47 PM
SEO by vBSEO 3.6.1
