-   -   Yamaha 9.9 help need (http://www.sailnet.com/forums/gear-maintenance/7092-yamaha-9-9-help-need.html)
nauticalrich 05-25-2003 04:43 PM
Now I am the happy owner of two boats, neither work.
My 9.9 Yamana 4 stroke apparently has no spark. It ran fine at end of season.
It''s about 5 years old. Changed plugs but didn''t help. What could have happened over the winter?
Any suggestions?
jparker11 05-26-2003 09:14 AM
nauticalrich,
Yamahas always start!! Verify the spark by pulling a plug and grounding it and pulling the starter rope.
No spark, check the kill switch and make sure you DO NOT have conductivity across the two poles.
Once spark is verified, move on to fuel. I don''t know if you have an automatic choke (Absence of a choke knob), but mine doesn''t seem to work. I defeat it by putting the gear selector in forward and giving two or three full throttle pumps. Return the gear selector to Nuetral and try starting. This uses the accelerator pump to enrich the mix at cold start.
Still stubborn, move on to the fine mesh fuel filter located on the fuel pump.
Also, did you close the fuel sump drain?
Out of suggestions without the manual!!
Good Luck,
