I am finishing a complete restoration of a SANTANA 39. My plans are to integrate a full enclosed cockpit (using a custom arch and canvas). In order to do so, I will have to relocate the traveler of the main sail to a different location.
More Images / Drawings
Now: The Main sail traveler is located (longitudinal) 3/5 of the boom right in the cockpit (seat level). The sheets, traveling from the traveler to the boom are right in the way and prevent any "encapsulation" of the cockpit.
Solution 1: Position the Main Sail traveler on the roof portion of the boat (move 4 feet forward) which would then be approximately 1/4 of the boom length. (attach-point on the boom being relocated accordingly)
Solution 2:I am building an arch that will be positioned in the rear of the cockpit. I could integrate material and additional structure support to accommodate the Main Sail traveler. The position of the traveler would then be located a little behind the boom (attach-point on the boom being relocated accordingly)
Question A: Although I would prefer to go with option#2, I have serious concerns about the effect of elevating the traveler (which is a fixed component) vs being low (originally)? Would the boat be less steady / performent sailing to weather?
Question B: On solution 1, considering the lever effect of the boom (attach point being moved forward), Is it a bad idea to add such stress on the roof, or would it acceptable considering proper reinforcement of the boat in that area?
Thoughts and ideas are welcome! Thanks
email:
mbrault@konsultech.com
