Old 01-01-2011
CalypsoP35's Avatar
CalypsoP35 is on a distinguished road
Winch Maintenance
Anybody have any secrets for cleaning the crud out of the gears and bearings in your winches?
Historically I've just wiped the old grease/crud out of the gears and re-lubed them. Removing the old crud out of the gears is always a pain. Anybody have any secrets? (My winches (manual Lewmar winches) have what I think are bronze gears and stainless bearings held in place by a plastic donut like holder.
Thanks in advance for any insights!
Old 01-01-2011
ardoin's Avatar
ardoin is on a distinguished road
Solvent in a bucket and an old tooth brush. I use diesel in a bucket since I have plenty of diesel on the boat and most marinas have a place to dump/recycle old diesel and oil.
Cy
S/V Music
MASON 44
Old 01-01-2011
Minnewaska will become famous soon enough
Mineral spirits
Old 01-01-2011
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Originally Posted by Minnewaska View Post
Mineral spirits
Amen... In an old plastic wash basin. Soak overnight and hit with a small wire brush the following morning. Do you winches at least bi-annually and you won't have a problem.
Old 01-02-2011
CalypsoP35's Avatar
Thanks for the info, sounds like a great solution.
Old 01-02-2011
I'd rather be sailing
labatt will become famous soon enough
And just for those reading this thread wondering about how to do winch maintenance - pulling my winches apart used to scare the crap out of me. I then did it for the first time and found that it's quite easy. The most complex part was making sure I didn't lose any pieces overboard during disassembly (it's recommended you cut a hole in a box and put it over the top of the winch during work - I was adventurous and just took my winches apart commando). Oh - and ditto on the mineral spirits.
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
Old 01-02-2011
Another trick. Pull the barrel off the opposite winch but leave gears in place and use as a guide for reassembly. You do need to disassemble to clean properly.
Old 01-02-2011
nickmerc's Avatar
nickmerc is on a distinguished road
I use terps which I can find cheap at the local hardware store. I use a firm toothbrush for the gears and very fine emery cloth for the pall seats. I find sometimes there is some stubborn oil and corrosion that needs persuasion. Be careful to not remove any metal when doing this.
________
Web shows
Lewmar old-school winch maintenance geary126 Gear & Maintenance 15 08-22-2010 10:07 PM
winch maintenance VictorJ Gear & Maintenance 3 03-26-2010 04:54 AM
winch maintenance Loualfr Gear & Maintenance 12 03-27-2009 05:17 AM
Winch Maintenance - Help with Older Lewmar 40s CLucas Gear & Maintenance 3 02-03-2008 07:50 AM
Winch Handle Maintenance tdw Gear & Maintenance 9 10-23-2007 07:42 PM
