01-02-2011
Finally found the needle!
Probable causes: - Piston rings
- Valve guides
- Valve springs
- Piston
In short, you have not provided enough information to make a clear diagnosis. Also $85/hr is NOT expensive for someone that knows what they are doing. Both of these factors lead me to suspect that you may not have the experience, knowledge and tools to properly repair the engine. Finally, as stated elsewhere, this is an old engine. Parts will be hard to find, and expensive if you can find them.
Here is what I suggest; Offer the mechanic $85 to diagnose the problem for you. You can decide if you want to tackle, or not. If you decide that you don't have enough experience, or the tools (you do have a torque wrench somewhere - right?) offer $170/hr for up to 20 (or some number that you are comfortable with) hours of work, with the condition that you will only pay IF the motor is fixed. (again, up to some limit that you could pay) If this mechanic can't fix it, or if he runs out of time, then you owe nothing. Realize that a new engine will cost you at least $10K.
Assuming that he goes for this, then you have yourself a GREAT deal. Though I suspect that he will not take you up on the offer.
Good luck!
