Dont Ever Do This - Page 2 - SailNet Community
 1Likes
post #11 of 32 Old 01-03-2011
Underwater Basket Weaver
TintedChrome's Avatar
Hey Quinn - just remember there's always somebody smarter, richer, prettier... and stupider than yourself At least you're not this guy:
Best of luck getting that fixed! Let us know how it turns out..
s/v Tinou
1976 Northstar Farr 727
Hull #37
I can't imagine mastering the skills involved here without a clearer understanding of who's going to be impressed.
TintedChrome is offline
post #12 of 32 Old 01-03-2011
Oh and I remounted the bilge pump with shorter screws.
The Sun has Risen on a New Day filled with the Promise of Adventure.
CapnBilll is offline
post #13 of 32 Old 01-03-2011
Courtney the Dancer
jrd22's Avatar
It takes a big man to admit his mistakes on this forum:-)) I like the plunger idea, it might keep it dry enough to grind a bit away on the inside and then apply some West and cloth. Then when you haul you can do a proper repair from outside. Keep us posted.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #14 of 32 Old 01-03-2011
You are going to have to make a bigger hole in the process of repairing it anyhow.. for now I'd put a washer on a short self tapping screw, goop it up and drive it home. Below the waterline you should have at least a half inch to work with (hopefully.. you must have good drill bits!!) The screw should come out easy enough when you're hauled for a proper repair.
We are talking strictly temporary here...
Faster is online now
post #15 of 32 Old 01-03-2011
Irrationally Exuberant
Whoa! OK, that one has to take the cake! Mind you I did something very similar inside my house while installing a subfloor with nails that were too long for the job. Took me all day to finally find dead center on a water pipe!
But Quinn, one hole? That could happen to anyone.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #16 of 32 Old 01-03-2011
ffiill's Avatar
Once upon a time in my youth I was fitting a new bathroom to the first house I owned.There was the copper water pipes and waste pipes around which I began to construct a wooden enclosure. In goes the nail down comes the hammer and as it came down I already knew what was going to happen next!
Then there was the bath all plumbed in but no waste pipe connected and no time to finish off that day.Dont turn the taps on I tell my wife;switch on the mains supply and water comes through the ceiling as I had never checked as to whether taps were turned off in first place.
Worst experience with boat was when suddenly whilst sailing the auto shower sump pump started discharging overboard-toilet did not have an anti syphon loop fitted and was flooding over into integrated shower basin.
Back to the house where I was chasing a cable run down the wall-again something told me as my hammer headed towards the top of the chisel to let go and sure enough I cut straight though a live cable leading to a wall socket!
ffiill is offline
post #17 of 32 Old 01-03-2011
mitiempo's Avatar
Quinn
I think Faster's idea makes sense. Thickened epoxy or Sikaflex under a fender washer with a self tapping stainless screw should do the trick.
I am very careful when drilling as it usually not my boat I am on. I do remember years ago a neighbor was installing something in his 41' powerboat and drilled into a gas tank - no spark luckily.
We all make mistakes but as minnewaska posted most of us keep quiet about it.
Brian
mitiempo is offline
post #18 of 32 Old 01-03-2011
ffiill's Avatar
Just recall a friend of mine a fireman.Welding under his Landrover with oxyacetlyene gear.Sudden bang and jet propelled fuel tank which used to be strapped outboard of chassis rail shoot out at right angles across work shop.No damage to my friend but as for the chip pan fat fire at the "Fire Station" thats another story!
ffiill is offline
post #19 of 32 Old 01-03-2011
toilet wax ring and a sheet of plastic, on the out side. will stop the flow for a long while as long as you dont go sailing.
scottyt is offline
post #20 of 32 Old 01-03-2011
mitiempo's Avatar
Faster's idea will be effective and can be done entirely from the inside.
Brian
mitiempo is offline
i really dont know a good title, sailing club 4 sale scottyt General Discussion (sailing related) 4 07-07-2009 06:04 AM
Johnson 9.9 Problem, please help, dont know where to look for advice:( Everlong Gear & Maintenance 6 04-22-2009 02:24 PM
Dont mess with the 12 incher mrwuffles General Discussion (sailing related) 17 01-09-2009 06:25 PM
DONT ORDER FROM SAILNET skipper22 General Discussion (sailing related) 7 08-29-2005 10:06 AM
if you dont have it you cant eat it starcresttoo Provisioning 0 08-31-2004 09:31 PM
