Old 01-04-2011
SiXeVeN is on a distinguished road
How to blind mount hardware to mast.
Hi all,
I would like to mount a rope clutch to my mast. Here's the rub... I obviously can't get inside the mast to put a backing plate or even place nuts on the back of the screws. I can't rivet it either as the mounting holes for the rope clutch are deep inside the unit... longer than the head for the rivet gun. I don't think the mast wall thickness is great enough to tap the holes to accept machine screws without tearing out under tension.
Anyone know of a rivet gun with a long thin head that can fit down inside the rope clutch mounting holes (about 2-3" deep and 1/2" wide)
Any other ideas?
Any advice is appreciated
Old 01-04-2011
jrd22's Avatar
Courtney the Dancer
Don't know what size boat you have but I've successfully drilled and tapped several masts with no problems.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 01-04-2011
tommays's Avatar
My J24 mast is about .095 wall and will hold #10-24 screws and as long as you use stuff life tef-gel they will come in and out
IMHP 10-24 is better than 10-32 for this type of stuff
If you feel the load is really high then you can make a plate with 4 screw holes and mount the clutch to it and then use 4 screws or rivets to hold the plate to the mast
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 01-04-2011
That is probably what I will have to do. Simple idea...I just need to make sure it doesn't end up looking too jury rigged.
Old 01-04-2011
Hudsonian is on a distinguished road
Marsen Klik rivet nuts are an elegant solution. As I recall I bought them through smallparts.com. I borrowed the setting tool from a friend who is an aircrft mechanic. The tools are frequently on ebay.
Preferred method for installing mast hardware? josrulz Gear & Maintenance 2 10-29-2009 11:11 PM
Input on mast/boom hardware required Finallybuyingaboat Gear & Maintenance 1 09-11-2009 09:53 AM
Dive Tank Mast Mount lgaggie96 Gear & Maintenance 2 05-29-2009 03:19 PM
Radar - Stern Mount or Mast Mount night0wl Gear & Maintenance 34 03-19-2009 07:00 PM
Seaview radar mast mount Neicy Gear & Maintenance 3 02-13-2006 12:37 AM
