01-06-2011
I have the Garhauer system on my boat and don't use the bungees at all. You generally don't need a cord to pull the cars aft... the sheet will do that if it is loaded to any degree. The only time you'd need the bungee cord or a cord to pull the cars aft is when you're sailing in really light air.
If you must have a bungee... use 1/4", but use the good stuff with the cloth covering so it lasts a bit longer.
