How to set up lazy jacks - Page 2 - SailNet Community
post #11 of 19 Old 01-10-2011
Paysay's Avatar
I put Lazy Jacks on my boat two years ago and I love them.
I designed a four part Lazy jacks system for a boom almost 16 feet long. The attachment points on the mast should have been placed so that the lazy jack would hold the end of your baton as the sail is furled. I didn't consider this and attached my lazy jacks just beyond the end of the baton (I have a full batoned main), allowing the end of the baton to fall off the boom. I'll fix that in the spring.
One thing I did right was to use a control line. My Lazy jacks are attched to the mast just below the lower spreader. I've never found a majic formula for determining where the lazy jacks are attached to the mast, but I'd suggest 1.5 to 2 times the boom length above the goose neck. At that point I mounted a Harken #233 Micro Block on the mast and ran the control line back to the goose neck with enought slack to allow the lazy jacks to be hauled down. A major complaint with Lazy Jacks is getting the baton caught on the lazy jacks as the main goes up. I can release the control line and gather the lazy jacks up to the control line cleat near the goose neck before I run the sail up. You'lll want this feature!
This cleat also secures the control line. Many plans show this mounted on the mast. Don't do it! Instead, mount it on the boom 12 to 18 inches from the mast. This keeps the control line away from the mast so it won't slapping at anchor.
It's a great DIY project and worth the effort. Good luck.
Paysay is offline
post #12 of 19 Old 01-10-2011
catamount's Avatar
My lazy jacks are made of spectra line with eye splices -- no hardware what-so-ever (except where the lines attach to the spars). No hardware to chafe on the sails, and the slippery spectra line also helps reduce chafe. They are re-tractable, too. They were made up for my by Chesapeake Rigging in Annapolis.
Peterson 34 GREYHAWK, West Boothbay Harbor, Maine
, a new voice for ocean conservation
catamount is offline
post #13 of 19 Old 01-10-2011
Paysay's Avatar
No luck posting a picture of my Lazy Jacks, but I must make a correction: I attached my Lazy Jacks below the top spreader, not the lower spreader.
Paysay is offline
post #14 of 19 Old 01-10-2011
I've written about it on my blog.
sailingdog is offline
post #15 of 19 Old 01-10-2011
Irrationally Exuberant
Catamount, what kind of eyelets are you attaching to on the boom and the mast? Looking to do this and need the details!
Thanks.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #16 of 19 Old 01-10-2011
Pogo-2's Avatar
ezjax system
Goto Lazy Jack System - EZ-JAX I used their system this summer on a Newport 30 and it worked great.
Capt Al
Pogo-2 is offline
post #17 of 19 Old 01-10-2011
catamount's Avatar
Something like this (RF1057):
(image from APS Ltd.)
But really any kind of eyestrap would work. There shouldn't been much load on your lazy jacks...
post #18 of 19 Old 01-11-2011
Thanks, Catamount. But now I see I have a couple of other questions:
1. Just so I understand, you have a cleat on the boom near the gooseneck, and the point where the line is attached to the mast is fixed. You loosen the blue line to release, but what keeps the now loose lines from flapping around? Do you attach the eye from the blue to red junction to the cleat or something?
2. What size spectra did you use?
Tom
Tom K
2000 Beneteau 331
arf145 is offline
post #19 of 19 Old 01-11-2011
catamount's Avatar
Yes, on mine, the attachment to the mast is fixed (I'm not sure I like this, though).
When we are retracting the lazy jacks, I loosen the "blue" line from the cleat that is on the bloom, gather the flapping lines and pull everything down and hook them (all the lines) under the reefing horns at the gooseneck (but could just hook them under the cleats on the boom if those are far enough forward), then I tighten the blue line again so that everything stays hooked, and belay the line to cleat again.
The line is a 12-strand single-braid about a 1/4" in diameter--probably much larger than you need from a strength perspective, but makes for easier handling. The eyes are made with short splices that are covered with heatshrink.
Lazy Jacks...yay or nay? corny Gear & Maintenance 48 01-13-2012 12:25 PM
lazy jacks Maineac38 General Discussion (sailing related) 31 12-21-2009 10:35 PM
Lazy Jacks on an S2 27 scuppers S2 0 05-08-2009 10:11 PM
Lazy Jacks/E Z Jacks DLM Gear & Maintenance 1 04-25-2009 05:22 PM
Lazy Jacks?? maureena5 Gear & Maintenance 12 11-15-2001 11:29 AM
