01-12-2011
Originally Posted by FirstLightVeroBeach
Thanks Mike I'll look into that. The leak is through a transducer.
It could also be that the hull is cored and that the hull core is leaking out through a badly installed transducer, which may have been how the water got into the hull's core in the first place. I really hope this isn't the case, cause this can be a really expensive repair.
