-   -   1 part poly paint success? (http://www.sailnet.com/forums/gear-maintenance/71212-1-part-poly-paint-success.html)
SailingWebGuy 01-10-2011 02:38 PM
Anyone ever use a 1 part polyurethane on their topsides with good success? I was thinking of using Interlux's Brightside for the decks and topsides.
tommays 01-10-2011 02:54 PM
1 part paint is much more forgiving at the cost of durability
I am still in the epoxy primer phase and have to say its a PITA to lay down a good coat of paint on a 30' boat with two part paint BUT i have stuff i spilled on the work floor two years ago that is pretty bullet proof compared to 1 part
I will see how it all works out this spring BUT so far i am in the regret phase of using the better paint
sailingdog 01-10-2011 04:11 PM
Second what Tommays has said about durability versus how forgiving the paint is.
Just remember that 99% of the success of any paint job is the surface preparation and priming. If you've slacked on that, it don't much matter what you put on top.
SailingWebGuy 01-10-2011 05:11 PM
How durable is a 1 part? Could it hold up to the straps on a lift?
Barquito 01-10-2011 05:22 PM
I used the same product on topsides and deck. I didn't thin enough on the topsides and ended up with some brush streaks. However, it still looked good. The deck looked good, but, got a bit beat-up. I think next boat I might use 2 part on the deck.
bljones 01-10-2011 05:29 PM
I painted our boat with Brightside last spring. I have been pleased with the results. Very forgiving paint that survived lift straps with no damage. Keep in mind that it does take time to fully cure and harden, so if you plan to splash shortly after painting, make sure the yard crew knows to wrap the lift straps in plastic before lifting.
http://i27.photobucket.com/albums/c1...ing2010052.jpg
sailingdog 01-10-2011 07:15 PM
Probably. :D I've beat the snot out of Brightsides on several boats and it's held up pretty well.
