01-14-2011
Applying heat to the tape and area of installation will allow you to install fittings with butyl tape in pretty cold conditions. Unlike most other sealants, it has no requirement to cure, so once it is applied, the cold will not be much of an issue. However, you may need to tighten up the fitting's fasteners a bit more once the weather warms.
