need hot water heater - Page 2 - SailNet Community
post #11 of 14 Old 01-12-2011
One of None
deniseO30's Avatar
Brian... the specs on precision.. 2 gal a minute is a trickle imho
Capacity:
55,000 Btu input - 44,000 Btu output at maximum burn at 8.5 WCI manifold pressure.
15,000 Btu input - 10,600 Btu output at low burn at 1.2 WCI manifold pressure.
(88F temperature rise per gallon per minute continuous flow at high burn).
Fuel Consumption: 2.55 lbs per hour at maximum input. ( At 2 GPM of water, 20 lbs of propane will produce over 940 gallons of hot water).
My last project!
deniseO30 is offline
post #12 of 14 Old 01-12-2011
mitiempo's Avatar
I guess that would depend how large your tank is and if you cared about being frugal with your supply or not. I have a 27' boat and my galley sink has a small Flojet pump rated at 1 gpm. But I am not looking for a water heater - of any kind.
Brian
mitiempo is offline
post #13 of 14 Old 01-12-2011
ffiill's Avatar
Propane safety-if you have a gas sniffer installed and mine has two sensors its impossible to get any gas from storage locker as without power the gas solenoid is shut.Plus you get a very noisy siren blasting off.
So you remove gas supply if portable;and start pumping bilge with your manual bilge pump to pump any gas overboard.
Whilst propane gas explosions do occur its not just as simple as gas plus a match.Mixture has to be just right.
Having said all of this my boat has a calorifier running off the indirect engine cooling system.
Once the engine is up to operating temp a little below boiling point so the 8 gallon calorifier is at the same temp.After a run into harbour mine is quite capable of giving several hot showers plus enough water to wash pots and have a warm wash the next morning.
It has the facility to add an immersion heater/heating coil for shore power although I have never found the need as if its available a nice shower onshore always seems more appealing.
ffiill is offline
post #14 of 14 Old 01-15-2011 Thread Starter
i guess there isnt a good solution , looks like i am going to use a small tank style heater.. thanks ...Ron
twisted23 is offline
LPG water heater WilliamWalker Gear & Maintenance 17 07-21-2011 12:34 AM
cs 30 water heater timmorgan CS Yachts 1 07-21-2009 07:01 AM
Connecting raw water cooling to water heater Northeaster Gear & Maintenance 18 04-28-2007 07:11 PM
hot water heater firstafair General Discussion (sailing related) 12 11-09-2006 11:25 AM
water heater docsabre Gear & Maintenance 1 04-30-2002 08:34 PM
