vinyl mats and galley counter - Page 2 - SailNet Community
post #11 of 18 Old 01-13-2011 Thread Starter
QuickMick's Avatar
good call on the remenants.... went to the flooring store and got this 4 1/2x6 piece for 15 bucks. its 'hospital grade' whatever that means.... i just always kinda thought vinyl is a bit chintzy, but heck if it works and looks good what the h e double hockey stick
url=http://deushost.com/i/2CQtLa.jpg][/url]
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Macgregor Venture
QuickMick is offline
post #12 of 18 Old 01-13-2011
I wouldn't recommend using flooring vinyl, even hospital grade, for a galley counter. It isn't designed for use as a food preparation surface and may leach chemicals into any foods that come into contact with it.
sailingdog is offline
post #13 of 18 Old 01-13-2011
Doesn't sail enough
zedboy's Avatar
Quick check: do people do their food prep directly on the counter surface?
I assumed the goal here was just a tough, easy-clean surface to work on, but actual cutting or whatever would be on something appropriate.
zedboy is offline
post #14 of 18 Old 01-13-2011
jackdale's Avatar
I expect that slicing and dicing is confined to cutting boards. But people may assemble their sandwiches on the counter top.
jackdale is offline
post #15 of 18 Old 01-13-2011
Senior Slacker
SlowButSteady's Avatar
I was thinking of redoing the countertops on my boat with cork. Sealed properly its pretty tough stuff (I've seen some really nice looking cork floors), and it also has quite a bit of natural water resistance.
SlowButSteady is offline
post #16 of 18 Old 01-13-2011
Dropping food on the surface could be a problem... so could spills and other things like that. Using food-safe surfaces/materials for a galley just makes a lot more sense.
post #17 of 18 Old 01-13-2011
bljones's Avatar
Diamond plate- tough, durable, easy to keep clean and offcuts are cheap.
bljones is offline
post #18 of 18 Old 01-13-2011
Allanbc's Avatar
He could cover the vinyl flooring with those flexible chopping cutting mats from eBay!
"When in command, command." -- Admiral Nimitz
Difference between a power boater and a sailor out on the water: A power boater is going some place special, a sailor is already there.
s/v Zotz 1981 Pearson 365 Ketch Hull #375
Allanbc is offline
Rope mats GoodOldBoat Good Old Boat 24 05-23-2015 05:46 PM
Galley counter-ceramic tiles QuickMick SailNet FAQ 10 10-07-2012 06:15 AM
Replacing galley counter L124C Gear & Maintenance 7 02-25-2009 02:15 PM
Judo or Exercise mats for Berth and Sette Cushions Brisco Gear & Maintenance 9 01-08-2009 04:39 AM
Repair of galley counter ricka Catalina 2 12-02-2006 10:32 PM
