Old 01-13-2011
QuickMick's Avatar
QuickMick is on a distinguished road
vinyl mats and galley counter
ive been looking around for material to cover the counter in the galley. tile is out, HD and lowes dont sell remenants of formica/corian, and the only sheet they would sell me is HUGE. so i got some of these
3-Piece 12" x 15" Flexible Food Chopping Cutting Mats on eBay!
and am thinking of using them for the project. any reason not to do this?
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 01-13-2011
jackdale's Avatar
jackdale will become famous soon enough
I have used similar ones. They score very easily. I would not use them as a permanent surface. I see them becoming a trap for bacteria and other nasties.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 01-13-2011
Allanbc's Avatar
Allanbc is on a distinguished road
Also, if you set a hot pot on them, they will melt.
"When in command, command." -- Admiral Nimitz
Difference between a power boater and a sailor out on the water: A power boater is going some place special, a sailor is already there.
s/v Zotz 1981 Pearson 365 Ketch Hull #375
Old 01-13-2011
jackdale's Avatar
Yep. Of course laminate would blister and Corian will not take heat either. Silicone pads are great as hot pads.
Old 01-13-2011
QuickMick's Avatar
when you used them as 'non-permanent' did you use any type of adhesive or just set them in place? thanks guys
Quinn McColly
Yacht Broker
Old 01-13-2011
zedboy's Avatar
Doesn't sail enough
zedboy is on a distinguished road
Why not get some remnants of vinyl floor? Tough, has a nice tile pattern, very easy to cut/work with, and can be picked up very cheap.
Old 01-13-2011
jackdale's Avatar
Kept them in a drawer and set them on the counter when needed. The fiddles on the counter prevents them from falling off.
Old 01-13-2011
What is the actual area required? I've often seen small sections (2'x4') available at supply stores.. plywood, arborite, etc etc.
Also check out kitchen builders and housing contractors for offcuts, leftovers and damaged bits. (Granite often cracks in transit!! ) Used building supply outlets, auction houses.... anywhere you might find some castoffs.
1984 Fast/Nicholson 345
Old 01-13-2011
Allanbc's Avatar
While true, those other surfaces are more forgiving than the plastic cutting boards.
Old 01-13-2011
Allanbc's Avatar
That is what I do. Sometimes I even used them on top of my wood cutting board because they are easier to wash than the cutting board or when cutting meat and you don't want to fully contaminate the cutting board.
Rope mats GoodOldBoat Gear and Maintenance Articles 13 12-11-2011 08:42 PM
Galley counter-ceramic tiles QuickMick SailNet FAQ's 9 11-23-2010 10:39 PM
Replacing galley counter L124C Gear & Maintenance 7 02-25-2009 02:15 PM
Judo or Exercise mats for Berth and Sette Cushions Brisco Gear & Maintenance 9 01-08-2009 04:39 AM
Repair of galley counter ricka Catalina 2 12-02-2006 10:32 PM
