Old 01-13-2011
YeahJohn's Avatar
YeahJohn is on a distinguished road
Easy way to fix broken wire.
This wire broke on my deck. It was installed in a bad place but whatever. It is a low gauge red and black dc wire coming onto the deck through a fitting, it is hooked up to a strange connector/adapter that then goes to a red green white wire for the mast light. I just need to re attach the red and black wire, how do I get more wire through the fitting? Help please.
1986 O'Day 272
Dana Point, Ca
Old 01-14-2011
szigi is on a distinguished road
Looking at the picture, and the sorry state of the connector, I would opt for replacing the whole connector, including the piece on the deck. If you need more wires, then buy a connector with more than two pins. Go for a good quality unit (even they are not expensive and can be bought at any boat shop), it can be really frustrating if it leaks, corrodes or breaks.
On my boat I actually used an industrial grade AMP manufactured connector from an electronics shop, it is about the same or higher quality than those sold at boat shops, and even cheaper.
Old 01-14-2011
I'd rather be sailing
labatt will become famous soon enough
This is the connector shown... we have a few of them on our boat too. I would tend to agree with szigi - looking at the state of the connectors I would recommend cutting back to clean wire and starting over. Of course this might be difficult if there's not enough slack.
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
Old 01-14-2011
Kiltmadoc's Avatar
Kiltmadoc is on a distinguished road
this was the solution i used for a similar problem and it's worked really, really well.
BLUE SEA SYSTEMS Thrudeck at West Marine
Broken shaft....and what else? stiffwind Gear & Maintenance 13 07-07-2010 10:55 PM
Broken Mast Help Please mountforever Gear & Maintenance 8 10-20-2009 11:56 PM
One Easy LAp stull General Discussion (sailing related) 4 02-02-2009 10:32 AM
Well ... that was easy bobmcgov Gear & Maintenance 2 03-10-2008 10:33 PM
Gyb’Easy Freesail99 Gear & Maintenance 33 02-05-2008 11:10 AM
