Old 01-19-2011
Sea Slacker
brak is on a distinguished road
Outboard help
I've got a little outboard that seems to misbehave - and no one locally that has a clue (and won't charge more than this thing is worth)
It's a single-cilinder 4 stroke Nissan. It seems to have a problem idling or staying in low RPM.
1. When under load, it will often shut down at RPM under the "low speed" marker (which is not good because at marker it's pushing my boat > 3kts).
2. When shifting into idle, even at low throttle, it will rev up like hell, sounds like a little crappy jet taking off.
3. From 1 and 2 - very difficult to use it for docking and close quarters movement, it will jump when put into gear, then shut down etc.
I tried:
- changing oil
- changing the lonely spark plug
- playing with a throttle/idle adjuster/whatever that's called
My knowledge of outboards ends right there. Ideas and help would be appreciated.
Old 01-20-2011
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
Sticky throttle linkage? Dirty carb? Gremlins?
Old 01-20-2011
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
Check low speed jet ( or slow jet ) and have the igniter checked, they have problems with them, if it's inside a couple yrs old, Nissan should replace it
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 01-20-2011
I'd rather be sailing
labatt will become famous soon enough
Ditto on the low speed jet... and gunk in the carb. We just had an issue with our outboard where it turns out the external fuel tank delaminated (most likely from the Bahamanian sun) and was shooting a gummy substance all the way through the fuel system. After three carb rebuilds (my wife did these) we ended up just replacing the carb and all the fuel lines from the tank through the outboard and to the carb.
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
Old 01-20-2011
DulceSuerna's Avatar
DulceSuerna is on a distinguished road
Remove the carb, dissasemble it, put it in the gallon of gunk carb cleaner overnight, throw out the motor, buy a honda ,
JK I had the same issue with my Honda, it was junk in the carb. The jets in those little 4 strokes are TINY, clean it out, blow it out, use cleaner and small wire,
Also, if you need to leave it sit for more then a month its best to drain the fuel from the carb.
Old 01-20-2011
LakeSuperiorGeezer's Avatar
LakeSuperiorGeezer is on a distinguished road
Junk
Originally Posted by DulceSuerna View Post
Remove the carb, disassemble it, put it in the gallon of gunk carb cleaner overnight, ... it was junk in the carb. The jets in those little 4 strokes are TINY, clean it out, blow it out, use cleaner and small wire,
If the motor suddenly developed the idle problem, then I believe it is most likely junk in the fuel. If you bought the outboard used with the problem, then it's probably the idle jet and dirt because someone tried to fix the problem by adjusting the idle jet. The only time I have adjusted the main and idle jets is going to a lake at 10,000 feet elevation. If there are no plastic parts, I have used lacquer thinner, but be careful around flames and light bulbs, or even dragging a metal pan across rocks with lacquer thinner because it is easy to ignite. Also, light bulbs have started many a gasoline fire while working on fuel tanks, especially if you break the bulb with fuel around on things. For blowing out parts, I have used those cans for blowing dirt out of keyboards and computers if no compressed air is available. Be very careful with the small wire as you do not want to enlarge any orifice. The fuel tank probably has junk in it so clean it out also. Maybe you could even fit a small fuel filter on the fuel line. Be careful taking the carb apart because on some there are little metal balls that are used as valves. If one bounces out, you do not know which passage way it came from. Draining the carb is good if easily done. Otherwise, I turn the fuel off with the engine running and tied to the dock. Let it run out and you will find very little fuel left in the carb bowel.
Old 01-20-2011
Sea Slacker
Thanks guys. So the general agreement seems to be "dirty carb". Now, since I have no clue - could someone provide slightly more detailed instructions?
I.e.:
1. Where is the carb? Is it the part on top of the main engine where throttle control connects (and that seems to have a little air intake)?
2. Does cleaning it mean I need to take it off completely and apart?
3. Any other clues (or, may be, a photo of what taking off the carb looks like)?
4. What is "low speed jet" and where is it located?
BTW I always run the fuel out (i.e. disconnect the hose and let the motor run out) after motoring. I guess it didn't help.
Old 01-20-2011
mattstamour's Avatar
mattstamour is on a distinguished road
Dude,
I feel your pain. Learning is expensive.
You may be able to google up a copy of the parts manual for your model that gives you a blow up with each part listed. That helped me gain the confidence to work on an old Johnson I had.
MattStAmour
Noank, CT
Catalina 30
Hull #222
Old 01-20-2011
Sea Slacker
I have a parts manual, but it's not entirely convenient to use for identifying things unless I already know what I am looking for. Which is why I am here
As an aside, I guess part of the issue is that I just don't like engines. I usually take anything mechanical or electronic apart easily and (most of the time) can put it back together too. With engines there is just this feeling that I don't want to do it - and they make little sense to me. No one can help with that
Old 01-20-2011
dabnis is on a distinguished road
Brak,
Before ripping the carb apart try mixing a carb cleaner,
such as Berryman's B-12 fuel additive, at about 50% with
gas and run the motor at all speeds for a while. Let it set,
without draining the carb, for a few says or so. Then run it
again with the same mixture. You may get lucky without
having to pull the carb apart. If not, be really careful when
taking it apart. Suggest working over a large clean towel.
Also, check for any possible air leaks at fuel line connections.
Dabnis
APS Outboard mxtommy Gear & Maintenance 26 12-17-2010 09:00 PM
Outboard on a P30 nelsonstruck P30 16 09-19-2010 05:04 PM
outboard on a Cal 21 bonito Cal 3 03-18-2010 01:32 PM
Done gone #@*%ed my outboard teddius Gear & Maintenance 16 07-27-2008 08:15 PM
Best Outboard windylake Learning to Sail 4 08-13-2003 09:07 AM
