Old 01-20-2011
Petar is on a distinguished road
Forced air heating delivery question?
I've finally figured out and fixed my older D4L Eberspacher diesel air heater. Fuel metering pump was the culprit not being properly setup for right amount of fuel delivery causing the heater to work intermittently. It works very well and exhaust a lot of hot air as it should. Originally it was (and it still is) setup inside the port cockpit locker with heated air ducting lead along the port side of the boat with four openings. The ducting is 25 years old and somewhat dirty/dusty. I am playing with an idea to just lead one main hot air exhaust into main cabin and with the pressure the fan delivers hot air will travel to forward and aft cabins. Do all of you guys having forced air heating use ducting along the entire boat with branches to each space? Bulkhead mounted heaters with small fan fitted heat boats easily and this one has a powerful fan that blows a lot of hot air. Any thoughts? pros and Cons are welcome.
Old 01-20-2011
sailjunkie's Avatar
Mirage 29
sailjunkie is on a distinguished road
Previous owners installed 2 or 3 ducts.
However, one of them decided to use only one duct, in the main salon on the port side. The ducting runs from the deep locker hatch to just forward of one of our coolers. It heats everything except the aft cabin quite nicely.
Changing it is not as high on my priority list as further work on the rigging and re-building the boom, plus a haul out this year. In fact, it's propane (brand name Propex) and I'll replace it with a diesel heater when it dies.
Mark
S/V Avatar
Mirage 29'
Port Moody, BC
It's not my fault they named a movie after our boat
Should Aussies Be Licensed and Forced To Wear Helmets? smackdaddy Off Topic 44 12-29-2009 04:16 AM
Delivery Run Question bfriberg General Discussion (sailing related) 4 01-11-2009 04:32 PM
Forced to Champaign SailinCowboy General Discussion (sailing related) 3 07-19-2006 03:30 PM
My Loss=Your Gain? Forced to cancel charter April 4-11 danderson09 Chartering 0 03-10-2003 11:07 AM
Heating Question pirateofcapeann Living Aboard 3 12-14-2002 02:12 PM
