cockpit engine access - Page 3 - SailNet Community
post #21 of 30 Old 01-21-2011
The Beckson deckplates are pretty solid and great for openings up to about 8" in diameter. They're a lot better than most of the other brands since they use a fairly coarse thread and are easy to seat properly without risk of cross-threading the plate. Also, their design allows them to be watertight even if you lose the o-ring.
sailingdog is offline
post #22 of 30 Old 01-21-2011
just do it
I say go for it. I've installed two large hatches in the cabin top this summer and with a bit of work it's certainly possible to make the resulting structure stronger than the original.
A steel frame was mentioned, though a plywood frame wrapped in and attached with three or four layers of fiberglass mat wetted out with epoxy would work fine also. Some of the aluminum hatches are probably strong enough by themselves to take up the loss of tension and torsion stiffness of the cockpit sole.
I would very strongly recommend to avoid the plastic hatches unless they are meant for use in a vertical surface that does not need any structural support and is virtually never subject to standing water.
S/V Isis
1964 Ericson Alberg 35
SailingIsis is offline
post #23 of 30 Old 01-22-2011
Sailor
Gladrags1's Avatar
This thread is interesting as cutting an access hole would work for me in gaining access to the stuffing box and back of the engine as well as the steering quadrant, etc. My friend had an Island Packet 32 which had a watertight hatch built in to the cockpit sole which provided great engine access. I would want something that is flush to the sole so the metal hatch might be the best for me. If you decide to do this, I'd encourage you to take pictures of the progress and let us know how things are progressing, both the good and bad.
Tod
Gladrags1 is offline
post #24 of 30 Old 01-22-2011
Sea Slacker
I had that on HR Rasmus. It's extremely convenient. The entire cockpit sole was pretty much an engine cover - so when opened, it was essentially engine compartment size. For service, I could just sit on top of the engine and reach pretty much anywhere.
The cover was not entirely waterproof though - not on my boat and not on any other Rasmus I've seen.
On another boat, I would do that provided I could make sure there is enough strength in the cockpit sole to maintain its integrity.
brak is offline
post #25 of 30 Old 01-22-2011
Old Gaffer
FishSticks's Avatar
This is the Anchor aluminum hatch. It's watertight, flush, and plenty stiff... widely used on commercial fishing vessels. Rose Marine in Gloucester had them in stock when I got this one. It dampens the engine noise quite well, but I added an inch of Soundown to the underside to make it quieter yet.
Never sail closer to the wind in degrees than your age
FishSticks is offline
post #26 of 30 Old 01-22-2011
Fishsticks—
Nice installation. BTW, where is the wheel on your boat, or is it tiller-steered?
post #27 of 30 Old 01-22-2011
Old Gaffer
FishSticks's Avatar
Here's the wheel, close behind the binnacle. Originally had a tiller which used up too much cockpit. Replaced it about 40 years ago with a $15 junkyard truck steering gear.
[IMG]Hosted on Fotki[/IMG]
post #28 of 30 Old 01-24-2011 Thread Starter
QuickMick's Avatar
View image: schem
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Macgregor Venture
QuickMick is offline
post #29 of 30 Old 01-24-2011
old guy :)
rikhall's Avatar
This is the access to the engine below the cockpit in our Irwin Citation 34:
We like it. And yes, I can easily climb down beside the engine to change the oil etc.
Rik
Irwin Citation 34
Mystery
rikhall is offline
post #30 of 30 Old 01-24-2011
My Etap 26 has an engine hatch in the cockpit floor. However the cockpit drains are actually in the gap between the raised inner seal ring and the deck. It also has very good gasketing, and is held closed by a pair of lines that tie off to cleats in the cabin. Access to the engine and saildrive is quite good.
Gary H. Lucas
GaryHLucas is offline
Access to behind the engine of a PSC37 johnbanfield Pacific Seacraft 15 01-20-2010 05:20 PM
Cockpit Locker & Engine Access Gasketing LittleWingCA Gear & Maintenance 6 01-10-2009 09:53 PM
Source for engine access hatch? bmwdad43 Gear & Maintenance 1 12-03-2008 05:52 PM
Irwin 43' center cockpit exhaust hoses access grsr Irwin 9 05-21-2008 05:11 AM
boats with easy engine, seacock, sea strainer, etc access night_raver Boat Review and Purchase Forum 3 08-26-2004 10:11 AM
